Old 10-19-2008, 08:55 AM
MrMille MrMille is offline
MrMille is on a distinguished road
Default USB not recognised when a known to be working USB key placed in USB slot
Well, the title pretty much says it all.
I have a perfectly good USB drive, and when placed into a clients machine, the little 'green arrow safely remove' icon appears, but the drive doesn't appear in explorer.
Why does this happen?
Old 10-19-2008, 09:49 AM
Simmy's Avatar
Simmy Simmy is online now
Super Moderator
Simmy is on a distinguished road
Send a message via MSN to Simmy
Dodgy USB drivers on the customers machine perhaps? Check in Disk Management to see if the dongle has been given a drive letter. Do other USB devices work in the clients USB ports?
Old 10-19-2008, 10:23 AM
Nah, USB mp3 player won't work either.
I suspect the people who 'manage' their machines are cowboys of the highest order. Even the auto update panel was greyed out with no options selectable
Old 10-19-2008, 10:51 AM
zchehi's Avatar
zchehi zchehi is offline
zchehi is an unknown quantity at this point
Default pirate
yep sounds like pirate software
Old 10-19-2008, 01:44 PM
jj2000's Avatar
jj2000 jj2000 is offline
jj2000 is an unknown quantity at this point
Send a message via Skype™ to jj2000
had a problem like this on a compaq laptop and it turned out to be a single connection on the actual usb socket was broken from the motherboard but this was a complete bitch to sort as it was such an intermittant problem.
freedom is only a hallucination
That waits at the edge of the distant horizon
And we are all strangers in global illusion
Wanting and needing impossible heaven.
Old 10-19-2008, 02:44 PM
Simmy's Avatar
Super Moderator
Good point - A good way to test the mobo usb controller is to try a USB PCI card and see if they work. If the PCI card doesn't sort it, then you're looking at a driver/software issue.
Old 10-20-2008, 03:21 AM
ICEinLAVA's Avatar
ICEinLAVA ICEinLAVA is offline
ICEinLAVA is an unknown quantity at this point
the USB header could have been connected to the motherboard incorrectly especially if you don't have a header block.
you may want to ask if the USB ports have ever worked or if he has just never used them.
Law of Probability Dispersal: Whatever it is that hits the fan, will not be evenly distributed.
Old 10-20-2008, 04:58 PM
tauzin23 tauzin23 is online now
tauzin23 is on the way
You might want to check inside "disk management" and make sure a drive letter got assigned to it. I had this happen before on a client's machine. I would plugin my usb flash drive and I would see the green arrow and hear a "da-ding" noise but my drive would not show up. I had to manually set the drive letter in "disk managment". The mapped network drive was already using the letter it was suppposed to use on their computer.
http://www.tauzins.com
  #9
Old 10-20-2008, 06:24 PM
jaydude23's Avatar
jaydude23 jaydude23 is offline
jaydude23 is an unknown quantity at this point
I agree about Disk Management. It happens to me all the time. I either have to change the drive letter to an unused one, or I have to give it a drive letter.
  #10
Old 10-20-2008, 08:32 PM
The machine did have several mapped drives...
