Go Back   Technibble Forums > Technical Discussions > Software Applications
Old 10-10-2008, 02:33 PM
Crgky127 Crgky127 is offline
Crgky127 is an unknown quantity at this point
Default HDD Regen on image
Has anyone imaged a failing drive to another new one, and then run HDD Regenerator on the copy? If so, what imaging program did you use? Acronis is getting hung up on the bad sectors.
Old 10-10-2008, 04:38 PM
14049752 14049752 is offline
14049752 is on a distinguished road
I use Roadkil's Raw Copy when Acronis fails. It does a bit for bit copy, and attempts data recovery on bad sectors. If the target hard drive is bigger than the source, you'll have to use Partition Magic or something to resize the partition after it copies (or make another partition, if you want).
After Raw Copy finishes, and if the drive doesn't boot, running HDD Regenerator on it won't do anything. The bad sectors aren't on the new drive, and if they were unreadable by Raw Copy, then there's nothing there to regenerate. CheckDisk will do MUCH more for you on the new drive.
