Old 01-27-2012, 07:44 AM
Captain Spaulding Captain Spaulding is offline
Captain Spaulding is on the way
Default Network Disconnecting
Hi,
Client has a windows 7 Dell desktop, they leave it running overnight and when they come back to it in the morning the interface shows disconnected and they have to reboot to get connected again.
I removed the adaptor from device manager and reinstalled the drivers, I also disabled power mgmt on the NIC. Problem still exists. Can't see any other obvious problems.
The desktop is wired direct into the back of the broadband router, the client also has a MAC that is plugged into the same router, that has no issues, it's still connected in the morning.
There are no problems during normal use in the day it only happens when left overnight.
Bit stuck on this one, anyone have any ideas?
Cheers.
Old 01-27-2012, 07:50 AM
Forgot to add, the computer is about 4 months old, client had no problems during the first couple of months, this has only started happenning recently.
MobileTechie's Avatar
MobileTechie MobileTechie is online now
MobileTechie will become famous soon enough
Get them to turn it off at night? Don't they care about global warming?!
Is the card set to go to sleep?
Any difference in IPCONFIG results before the problem and after?
Old 01-27-2012, 08:14 AM
Unfortunately they need it running during the night for some reason.
The card has "Allow the computer to turn off this devices to save power" unticked in power management.
Although it does seem like some kind of power mgmt / idle setting that's causing this as it never disconnects during the day when it's being used.
The port in the router and the cable has been swapped and the MAC does not suffer the same issue.
Guess I could leave a constant ping running see if that makes any difference but I need to find out what the cause is really.
Old 01-27-2012, 10:22 AM
markcuk11 markcuk11 is offline
markcuk11 is on a distinguished road
Stupid question but is set to stay on ie not set to go to sleep etc
you might want to read this thread http://answers.microsoft.com/en-us/w...2a7e1ba?page=2
Old 01-27-2012, 11:22 AM
I'd get them to send you an IPCONFIG report after it's stopped working to rule out some config error occurring for some reason.
Maybe check all Scheduled tasks to see if something is happening at night. I once had a client where their screen turned upside down every night when they were asleep. Turned out to be a registry cleaner set to run at 2am.
It would be interesting to find out if there was any way of getting it working again other than power cycling it - e.g. resetting the IP config, taking out the AV etc - might give you the clue you need.
Old 01-27-2012, 11:46 AM
YeOldeStonecat's Avatar
YeOldeStonecat YeOldeStonecat is offline
YeOldeStonecat is just really niceYeOldeStonecat is just really niceYeOldeStonecat is just really niceYeOldeStonecat is just really niceYeOldeStonecat is just really nice
It's probably still set to go to sleep or standy or hibernate at night...set power management to "Always On, never never never".
Resident "Geek on a Harley" doing IT in Southeast Connecticut
http://www.dynamic-alliance.com/
https://www.facebook.com/YeOldeStonecat
