Old 11-10-2011, 04:20 PM
KrazyBytes KrazyBytes is offline
KrazyBytes is an unknown quantity at this point
Default Dell Laptop LCD Dark
I had a customer bring in a DELL laptop and it appeared that the backlight was out on the LCD. I ordered a new and it still lookst the same. Will whole mobo have to be replaced?
Old 11-10-2011, 04:26 PM
Trusted IT Solutions Trusted IT Solutions is online now
Trusted IT Solutions is on a distinguished road
Perhaps the inverter needed replacing...not the screen.
Old 11-10-2011, 05:20 PM
Inverter is part at the bottom of the screen correct? It can with the new screen.
Old 11-10-2011, 05:29 PM
Martyn's Avatar
Martyn Martyn is online now
Administrator
Martyn has disabled reputation
Do you mean it came with the new screen? That's not usually the case as it is a separate item. This component, usually at the bottom below the screen, fires up the screen backlight so if your screen is dim it could be screen backlight(replace screen) or the inverter(replace the board) or indeed the inverter supply cable.
Old 11-10-2011, 05:33 PM
The inverter is a separate piece below the screen. One end of the inverter connects to the video and the other end connects to the backlight.
Old 11-10-2011, 07:25 PM
Hmmmm. I'll check that out.
