Xp cannot load profile, opens a temp profile with no Documents
Client was in a big hurry as assignments were overdue. I had to make haste I created a new profile and moved everything over and told her to delete old one once She was absolutely sure nothing was missing I was wondering if there was an easier way of doing this, or anything in D7. This is quite a common problem P.S. I called D7 a confounded program once, I eat my words it’s the best thing availably If you’re not using this you’re in the Stone Age |
I haven't seen a corrupted profile in a while, but I've always pretty much done what you did. But you're right there has to be a better way. I think this can have several causes, don't quite remember. I know a corrupted NTUSER.DAT file (the user registry that ends up being HKCU when you login.) One option might be to simply delete it - unknown if a new one will get created or if Windows still logs you into the temp profile. Maybe overwrite it with the default NTUSER.DAT is a possibility... Then there is the user profile location registry hack not sure if that would solve this issue. Similarly there is user shell folder redirection... Perhaps just create a new user profile and instead of moving the files from the corrupted profile, just use folder redirection in the registry. A neat idea, but that's a little sloppy for my tastes. Will have to do some experimentation on this. Does anyone know how to actually CAUSE this problem???? Quote:
Author of d7, and TONS of other FREE PC technician's tools. www.FoolishIT.com Checkout my videos on d7: An introduction to v6.6.x and Configuration Overview Also check out My Network Boot Setup details, and the comment thread. Boot diag CDs over the network / deploy Windows installs with updates, drivers, and pre-installed apps in minutes! |
What about this:
Reprofiler – Repair Tool of the Week http://www.technibble.com/reprofiler...l-of-the-week/ |
| Thread Tools | |
| Display Modes | |
