Thread Tools | Display Modes |
I'm totally stuck on this one.
I was restoring a computer (Windows 7 HomeP) when it rebooted and now, after the Dell (Inspiron 1720) POST screen, am presented with a flashing cursor against the DOS-like black screen. I have run full diagnostics and it is NOT a hardware issue. Originally, the PC was assigned to me because it had startup issues. I ran the Dell restore process and was successful. It booted, I didn't encounter any issues, installed WIndows updates, it rebooted, and now I'm stuck. I CAN NOT access Safe Mode, I do not even get presented with a Windows loading screen or ANY error messages. It's as if there's nothing on the HD (but I am not given an Operating System Not Found or No Media error). When i use my Windows 7 Restore Disc to try and restore to an earlier restore point, it fails. I haven't tried to do a full reinstall yet because I want to fix this issue (and don't feel like pulling the hard drive to copy the files I backed up). Any ideas? Any commands I can run from the console? Perhaps I should try the UBCD? I'm totally stuck on this as I have never encountered this issue before.
Computer Repair, Laptop Repair by digitalctrl ( i'm strange...a little bouncy...sometimes obnoxious...but I'm far from being a n00b! ) Lansing's geek alternative squad |
I'm going to cry... *LOL*
I finally discovered that the fixboot and fixmbr is changed for Vista and Win7. It can be performed via bootrec.exe /[appropriate command]. Now, I also discovered by running bootsec.exe /scanos that there are "0 Windows installations detected." Sad because I just restored the PC, installed some updates, and now i'm getting this message. There must be something I can do without performing a complete reinstall??
I don't mean to keep posting replies to my own thread but I wanted to keep you all updated and, in-case anyone else encounters this, here's a KB article you can use.
![]() http://forums.techguy.org/windows-7/...tions-0-a.html I did have to change the last drive letter to D: to correspond with the Windows installation. NOW... the system won't boot but I at least got past this blinking cursor!
check boot.ini and mbr reinstate the settings, you should be good to go.
Have you tried to run the windows start up repair? I would also back up and remove the old bcd and rebuild a new one rather than trying to repair it. Code:
bcdedit /export C:\BCD_Backup c: cd boot attrib bcd -s -h -r ren c:\boot\bcd bcd.old bootrec /RebuildBcd Last edited by TLE; 09-29-2011 at 03:33 PM. |
| Thread Tools | |
| Display Modes | |
