Old 09-26-2011, 03:57 PM
Trusted IT Solutions Trusted IT Solutions is offline
Trusted IT Solutions is on a distinguished road
Question repair install help.
Hello all. Is legal for me to use any windows 7 installation disc to do repair installs on win 7 machines? Would it work? I believe it would but plz correct me if I am wrong. Thanks.
Old 09-26-2011, 04:04 PM
PaulRome's Avatar
PaulRome PaulRome is offline
PaulRome is an unknown quantity at this point
Give this a read.
http://www.sevenforums.com/tutorials...r-install.html
Best of luck
Old 09-26-2011, 04:32 PM
shamrin shamrin is offline
shamrin will become famous soon enough
To be legal, the owner has to have a valid license and, in all cases I know of, the Windows install media. This means either a disc, an installation partition on their drive or re-installation discs from the computer manufacturer. If these criteria are met, then you should be OK.
Hartland Computer Services, Lexington, Ky 40515
(859) 536-4107
www.CrosbyDrive.com
Old 09-26-2011, 04:33 PM
Thanks PaulRome. It says I need to repair install using an install disc that is the exact same version of win7 that I am repairing. Now suppose I use the eicfg removal utility on any win7 .iso. Would I then be able to use that .iso to do a repair install on any version of win7? Thanks.
Old 09-26-2011, 04:57 PM
PaulRome's Avatar
Not really positive, think it may work. Don't see why it wouldn't. I would clone the disk first in case it doesn't.
Best of luck
Old 09-26-2011, 06:57 PM
FoolishTech's Avatar
FoolishTech FoolishTech is offline
FoolishTech is a jewel in the roughFoolishTech is a jewel in the roughFoolishTech is a jewel in the rough
It will work, yes. But it will not be legit. Using any means to modify Microsoft's Windows media is a violation of their terms. Only Microsoft Licensing (which is a separate company from Microsoft proper) has the rights to create/modify Windows installation media; with the exception of creation of media by the end user as a direct result of the method the OEM provides (i.e. burning a restore CD as some OEM's will prompt you to do as part of, or after, the OOBE).
Author of d7, and TONS of other FREE PC technician's tools. www.FoolishIT.com
Checkout my videos on d7: An introduction to v6.6.x and Configuration Overview
Also check out My Network Boot Setup details, and the comment thread.
Boot diag CDs over the network / deploy Windows installs with updates, drivers, and pre-installed apps in minutes!
