I've got a little utility that does a check on the Smart status of a drive. I'm writing a script that checks a bunch of things and I want to include the ability to parse the text from this utility. Problem is, I don't have a drive here that's failing SMART to run it on. I want to get a report that fails the test.
http://beyondlogic.org/solutions/smart/smart.htm is the address of the little utility. If you run it from CMD (saved, for example, to your C:\ folder): Quote:
Not a fail as such, but 4 re-allocated sectors - hope it helps:
SMART & Simple for Windows NT/2000/XP V1.01 Copyright 2001-2003 Craig.Peacock@beyondlogic.org Opened Drive \\.\c: . . SMART Enabled : Yes Model Number : Maxtor 6E040L0 Firmware Version : NAR61590 Serial Number : E14XP57E Drive Size : 41.110 GB ID Attribute Type Threshold Value Worst Raw Status ---- -------------------------- ----- --------- ----- ----- ---------- -------- [03] Spin Up Time Prefailure 63 219 219 10391 OK [04] Start/Stop Count Advisory 0 253 253 524 OK [05] Reallocated Sector Count Prefailure 63 253 253 4 OK [06] Read Channel Margin Prefailure 100 253 253 0 OK [07] Seek Error Rate Advisory 0 253 252 0 OK [08] Seek Time Performance Prefailure 187 248 238 46289 OK [09] Power On Hours Count Advisory 0 70 70 14114 OK [0A] Spin Retry Count Prefailure 157 253 252 0 OK [0B] Calibration Retry Count Prefailure 223 253 252 0 OK [0C] Power Cycle Count Advisory 0 252 252 534 OK [C0] Power-Off Park Count Advisory 0 253 253 517 OK [C1] Load/Unload Cycle Count Advisory 0 253 253 1184 OK [C2] Drive Temperature Advisory 0 253 253 39 OK [C3] ECC Corrected Count Advisory 0 253 251 34523 OK [C4] Re-Allocated Data Count Advisory 0 253 253 0 OK [C5] Pending Sector Count Advisory 0 253 253 0 OK [C6] UnCorrectable Sector Count Advisory 0 253 253 0 OK [C7] CRC Error Count Advisory 0 199 199 0 OK [C8] Write Error Rate Advisory 0 253 252 0 OK [C9] Unknown SMART Attribute Advisory 0 253 252 0 OK [CA] Unknown SMART Attribute Advisory 0 253 246 0 OK [CB] Unknown SMART Attribute Prefailure 180 253 252 2 OK [CC] Unknown SMART Attribute Advisory 0 253 252 0 OK [CD] Unknown SMART Attribute Advisory 0 253 252 0 OK [CF] Unknown SMART Attribute Advisory 0 253 252 0 OK [D0] Unknown SMART Attribute Advisory 0 253 252 0 OK [D1] Unknown SMART Attribute Advisory 0 188 182 0 OK [63] Unknown SMART Attribute Advisory 0 253 253 0 OK [64] Unknown SMART Attribute Advisory 0 253 253 0 OK [65] Unknown SMART Attribute Advisory 0 253 253 0 OK |
ok I was gonna trash that drive anyway, so I hooked it up to my test rig and smacked the hdd about a bit - Crystal Disk comes up with a "Caution" and:
[05]Reallocated Sector count: 1BF [C5]Current Pending Sector count: 95 but when I run the smart.exe against the drive it just says this: SMART & Simple for Windows NT/2000/XP V1.01 Copyright 2001-2003 Craig.Peacock@beyondlogic.org Opened Drive \\.\e: . . and that's it! I've run it a few times and always the same. CrystalDisk is still stating the same though. So it might a no news is bad news kinda thing
My general rule is if Cystal reports caution due to bad sectors, I warn the client they best get new drive as the risk of failure is high.
same here mate, once it starts it'll only get worse
Thanks, guys.
Ultimately, I can't skimp on the info. I'll still want to look for Reallocateds (etc) even if it's marked as "OK". Parsing that kind of info would be a real pain so it's looking like I can't simply parse for "Not OK" and save time that way. For the sake of things, I may have to go through the process of running CDI/HDTune and using their Copy features. Actually, I just did it with HDTune, just need to test it out further. I'll save the copied text as variables and add those variables to the report I get at the end. I'll {sigh} have to actually read it but que sera.
Xander St Catharines Computer Repairs New here? Watch this and read this. Remember, it's not our problem, it's yours so ask your questions well. |
If anyone's curious to try the rough draft of this section, it's zipped below.
It needs to be run in a folder containing "DiskInfo.exe" (Crystal) and "HDtune.exe". Pops out two windows after with their results. |
| Thread Tools | |
| Display Modes | |
