I have an HP dv5 -1002nr in the shop and im running into this problem for the first time. The screen on the LCD is dim, naturally one would think inverter or back-light. I have about 10 cracked LCDs i keep around the shop to test just for such problems. I hooked up a good known working back-light (attached to a cracked lcd) followed by 2 more and the screens are still dim, i already tried the brightness setting and hooking up to an external monitor shows a perfect display. I purchased a new inverter and the display is still dim, my next course of action is to replace the lcd cable, perhaps the inverter power leads are damaged. has anyone encountered this, a dim display caused by a faulty lcd cable?
It very well may be a cable that is bad. Generally these things have an input of 3-5v, 3v being the dimmest, and 5v being the brightest. If that wire is broken it would be conceivable that the inverter is seeing 0v on that input and giving you the lowest light.
Haven't personally seen it before though.
Aaron Heidlebaugh Computer Technician / Owner www.AaronsPCSupport.com 804-307-4465 (Call or Text) Laptop LCD repair | DC Power Jack Repair | Virus Removal Desktop Repair | Hardware | Software | Troubleshooting |
To make things even funner i can't even find a reference to a magnetic lid switch..
Just for reference, the problem was indeed an electrical cable in the LCD cable bundle that had broken with time and torsion. This cable provided power for the inverter, never discard the LCD cable as a possibility with a dim screen suggesting the problem to only be an inverter problem or backlight.
I am in a similar situation. I have a dell inspiron 1501.
Hooked up to external monitor it works fine. Screen is dim and then you see nothing. I have changed the screen, lcd inverter and lcd cable and I get the same results. I guess its the port that the lcd cable plugs into/motherboard replacement?
Keep Calm and Chive On! |
Thanks soooooooooo much, you just saved me a lot of money..and my client too. One question, so if the client closes the computer it will not actually put it to sleep so they need to actually shut it down or put it to sleep manually?
#9
Yeah the lid switch serves 2 roles in some machines it puts the laptop on standby and shuts down the lcd backlight. Offer a replacement for your fee of course, they sell the switches on ebay make sure you find just the right part on ebay take your time. You can set the pc to go to sleep by simply pressing the power button ensure this is set on power options in OS. I'm glad i could help, and good luck with your business.
| Thread Tools | |
| Display Modes | |
