I need advice to see if I can install a SATA pci card into a Compaq ProLiant ML570 G2 Server
A customer needs more space and a new ultra160 hard drive on Ebay is about £300 for 146Gb. I tried all my normal suppliers but they don't stock any scsi hard drives now. As you can see it will be much cheaper and better performance if I can use a SATA hard drive but as I have not done it before I thought I would ask first. |
Can't see any reason why not. What OS?
sorry forgot to say.
Server 2003 standard |
Dont see why not either. End of day its simply a way to add drives, OS wont see it any different.
Not same but I put a SATA PCI into a WHS system and added two SATAs and it went fine and works Ok. As its based on 2003 no reason it wont for your scenario. |
just an update,
The BIOS picked it up no problem but now it will not boot from it's original SCSI hard drives no matter which order I put them in, in the BIOS. It always looked at the new SATA hard drive and as it was blank it assumes no OS was installed. I ran out of time as the guy that let me in was in a rush so hoping to go back out tomorrow to investigate. |
We have a very similar issue on a job we are working on. Thanks for the updates. I will post results back here as well.
Might need to install a bootloader on the SATA drive and point it towards the scsi.
Silvano Vanegas- Co-Owner and Lead Technician Geek Easy Kalamazoo, MI Computer repair. 269-548-TECH (8324) Follow us on facebook or twitter too! Follow Geek Easy Computers on Facebook or Twitter also. |
Doublecheck the list of 'hard disks' in the BIOS boot order and listing.
Also, you may have to tell the SATA card to work as RAID/JBOD and tell it to present itself to the BIOS as a bootable/interuptXY device.
-- With Friendly Regards, Wim Wauters - Unisoft Design Managed ICT Service Provider for professionals and small to medium size businesses Data Recovery and Password Recovery in Rushden, NN10 |
#9
Thanks for the replies I will try them at the weekend when I can get access again.
The HP had 2 sections for booting up, the first was by dvice i.e dvd, floppy, hard drive & network. The second part was hard drive order, I put the new SATA card as last but it made no difference. I will try the other options when I get the chance. |
#10
It's worth bearing in mind why servers have SCSI drives - they are like 10x more reliable than ATA/SATA. So whatever you do, make sure it's RAIDed.
| Thread Tools | |
| Display Modes | |
