Hello..
I got a HP DV6 in my shop.. customer sent it in because, loading and using windows 7 is suuper slow and hangs.. so i tried tinkering with it.. 1. Initially, I entered safe mode. It loaded fine, and responds quicker inside windows. 2. Tried restoring windows coz i thought it was a virus that caused it. (no effect) 3. Checked disk using windows 7 4. Checked disk inside BIOS. .. (still no effect) 5. entered safe mode, updated antivirus, -- then the system crashed , Blue screen of death! 6. Then rebooting showed an error BOOT DEVICE NOT FOUND Please istall an operating system on your hard disk. Hard disk (3F0) 7. now when i enter bios, it cannot detect the hard disk. 8. Took out the hard disk, and installed in another hp laptop. It booted up and entered windows fine (though still a bit slow) 9. installed a different HD on the dv6 laptop and still it can't detect the new HD. 10. Already tried loading set up defaults in bios. now im baffled.. looked in the net.. a lot of this issue with the specific model. no clear solutions yet though..
Have you tested the ram ?
and have you cheeked the Blue screen code ? |
yes, RAM tested ok in the BIOS check.. .. and too bad I wasn't able to get BSOD code..just flash quickly and laptop rebooted itslef.. |
Hard drive diagnostics?
hello TLE..
nah..! .. its ok.. i came here to seek help and hoping some guy experienced this same prob.. .. i welcome every suggestion.... hmm.. but to answer... yes, i did suspect the hard disk too.. so here's what i did to test the hard disk.. 1. took it out, and placed it as a slave in a desktop pc.. i could access all files without a problem, and was even able to run a chkdisk on it.. 2. tried to boot it on a desktop pc, it went as far as windows splash screen before rebooting. 3. also tried putting it on another HP laptop with a different model.. entered windows normally! .. (this made me think that the hard disk is ok) 4. tried a working (different one) hard disk on the laptop, and yes, same error.. disk cannot be detected also |
i am about to try this one out.. but hmm.. found a lot in the web that they already tried this.. and nada.. most of them ended in bringing the laptop to a repair shop.. ![]() now my problem is.. i'm the repair man.. hehe.. the problem is thus passed on to me.. i just don't want to conclude that this laptop has a bad mobo that quickly though.. |
Being able to access files and perform a chkdsk (which could severely damage a faulty drive by the way) won't tell you very much at all about the state of the hard drive. You need to do some proper diagnostics
My bad, I removed the post as I re-read your original post which stated that you had tried an alternative hard drive which was also not recognised. Since this is a DV6, does it have the NVidia GPU installed which causes nothing but problems? Last edited by TLE; 07-21-2011 at 03:14 PM. |
#9
now i learned something new..
NEVER RUN CHECK DISK ON A SUSPECTED BAD DISK.. .. thanks.. .. i'm currently installing these HD diagnostic tools to try it out.. but i'm really wondering since this HD boots fine on a different laptop.. but would still give it a go though.. ![]() Quote:
oh.. something i just noticed too.. that the dvd/rom just lights up and is not working now.. it was working before when i was still able to access windows.. |
#10
Have a look at the models specs online and see what GPU it's using. NVidia G84 and G86 GPU in the 8400M and 8600M series of cards are affected.
Symtoms vary and it doesn't just affect the graphics. |
| Thread Tools | |
| Display Modes | |
