Old 07-11-2011, 05:47 PM
Jsch38 Jsch38 is offline
Jsch38 is an unknown quantity at this point
Unhappy Need Help removing AVG on WIN XP
I had installed AVG free Edition on a dell insprion 1521 laptop.
I then decidied to remove it using the AVG removal utility.
I ran the utility and restarted the system.
The screen still displays the AVG icon on the dektop and in the quickstart meun in the taskbar at the bottom of the screen.
I then found the AVG folder in Programs Folder and deleted it. I also tried the AVG removal utility again. & restarted the laptop. I still have the same issue.
Any Suggestions ?
Thanks In Adavnce For Your Help
Old 07-11-2011, 05:52 PM
homebase's Avatar
homebase homebase is offline
homebase is an unknown quantity at this point
I've seen AVG removals fail if something (usually malware) has taken away your rights to modify the HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Windows key. Remove the deny permission that was added and try the removal again.
Neil Winchell
Home Base Computer Services
Sacramento computer repair Sacramento laptop repair
Old 07-11-2011, 08:10 PM
johnrobert's Avatar
johnrobert johnrobert is offline
johnrobert is on the way
Check Msconfig see if it’s still in the startup if not it was probably removed
Also check services not used by Windows see if its there
You will have to deleted anything that shows up in a search
I don’t use AVG anymore it causes too many problems, I use Avast free not the best I’m sure
But works without a problem
Old 07-11-2011, 09:02 PM
commodore64's Avatar
commodore64 commodore64 is offline
commodore64 is an unknown quantity at this point
We had one like this, avg wouldnt uninstall, and avg removal tool didnt work, We just reinstalled avg again over the previous install, then restarted, and removed it in add/remove programs. Hope this works for you.
Compudoc Computer Repair
Old 07-11-2011, 09:32 PM
Martyn's Avatar
Martyn Martyn is online now
Administrator
Martyn has disabled reputation
Done this myself, install it with the latest version then uninstall it. Should remove the lot.
Old 07-12-2011, 01:39 AM
johnrobert's Avatar
Why didn’t I think of that only problem is if old was ver 9 you install 2011?
It’s not going to work very well
Old 07-12-2011, 06:32 AM
bitznpcz bitznpcz is online now
bitznpcz is on the way
You can download old versions from FileHippo (http://www.filehippo.com/download_avg_antivirus_32/)
Kevin Walker
Bitz 'n' PC'z Ltd
Chesterfield Laptop & Computer Repair
Old 07-12-2011, 11:38 AM
PC-Man's Avatar
PC-Man PC-Man is offline
PC-Man is an unknown quantity at this point
Use revo uninstaller. The revo uninstaller will completely uninstall the AVG including all it's registry entries
  #9
Old 07-12-2011, 12:04 PM
ubuzz ubuzz is offline
ubuzz is an unknown quantity at this point
I would try Revo Uninstaller as well.
  #10
Old 07-12-2011, 05:30 PM
Smile Problem Fixed
I was using an older verison of uninstaller tool from AVG. I downloaded and ran the latest uninstaller from their site and ran it. AVG was completely removed.
THANKS FOR ALL THE HELP
Tags
avg
