Hi all,
here's a nice one: I removed a trojan (forgot the name, didn't look interesting at the time) from 2 machines from the same customer. I had to unhide desktop icons, program folders & documents, etc... Now the desktop icons still won't show. Checked the usual registry places, ACL, ownership etc... Also, the desktop context menu won't show at all. Now, here's the kicker: other accounts on the same machine do NOT have this problem... is there some kind of diff application for the registry, so I can easily compare different user sections? IMO, my best option is to create a new user profile and copy their stuff across from their corrupted/messed-up profile.
-- With Friendly Regards, Wim Wauters - Unisoft Design Managed ICT Service Provider for professionals and small to medium size businesses Data Recovery and Password Recovery in Rushden, NN10 Last edited by wimwauters; 07-04-2011 at 08:22 AM. |
It's simple really: run unhide.exe from within the user account again,
and now everything does come back as normal. Go figure. Machine was tested clean with HitmanPro and TDSSkiller http://download.bleepingcomputer.com/grinler/unhide.exe
-- With Friendly Regards, Wim Wauters - Unisoft Design Managed ICT Service Provider for professionals and small to medium size businesses Data Recovery and Password Recovery in Rushden, NN10 |
Here's a fix I think it should work:
Login to a user account where everything works well. Export the following registry keys: HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\HideDesktopIcons HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\Advanced HKEY_CURRENT_USER\Control Panel\Desktop Log off, and login to the damaged account, import the registry scripts, and run the following command as admin: regsvr32.exe shell32.dll Reboot. Hope it helps. |
Excellent idea Eureka, almost as good as a diff :-)
I've dealt with that same virus. The problem with unhide.exe is that it affects all files. What I found is that you can run system restore after the infection is gone. This sometimes work.
Take a look at this:
http://www.technibble.com/forums/showthread.php?t=28661 It's a registry entry that's been deleted. Context menu is disabled and "Show Icons on Desktop" is also disabled. Obviously you're not to know this as the context menu isn't available. I fixed it after a good think and came up with the above conclusion. To fix do the following: Go to the following in REGEDIT: HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Policies\Explorer The key "NoViewContextMenu" shouldn't be there if you have the same strain as me. I had to add a new DWORD value, create it and set it to "0". When I restarted everything was back to normal.
http://www.adeptpcrepair.co.uk - Laptop Repair Cardiff Last edited by Adept PC Repair; 07-04-2011 at 05:13 PM. |
I find it disappointing good old google did not show me anything like the "NoViewContextMenu" key. At least we can still use google to replace this forums search function
![]() Thanks all for your contributions, much obliged!
| Thread Tools | |
| Display Modes | |
