Hi guys,
Hoping someone out there has come across this problem before. Took a Dell Laptop in the other day and the internet connections on the wireless card and ethernet ports were working fine. Updated to Service pack 1 and now neither will connect to the internet. A lot of the time the 2 screens with a ball icon comes up showing it connected but there is no access to the internet. Device manager shows the wireless card and the ethernet card along with 8 entries for 6to4 adapter with yellow exclamation marks. Ipconfig/all shows lots of tunnel adapter local area connection media disconnected settings but no settings for the network. I can ping the router no problem but nothing outside of it. I have updated the drivers on the ethernet card and the wireless card and tried disabling ipv6 in the tcp/ip settings and turned off the firewall on the laptop and still I can't get a connection. Any ideas would be most welcome. Cheers, John. |
Disable Ethernet card, Try WPA personal instead of AES or WPA2 on the wireless. Right click on the connected network and select properties.
Hope this helps. |
Hi PC Man,
Thanks for getting back to me. Will give that a go. Just tried again with the cable connected to the ethernet port and I can ping www.google.com and it replys as normal. Network connection in system tray shows local only connection without the blue wheel symbol. The browser opens but claims it can't find a connection. Any more ideas anyone? Cheers, John |
What Security software is installed?
Have you checke the Host file? Reset TCP\IP? Rebuilt Winsock? |
Hi guys,
Thanks for this. Tried the first suggestion to no avail I'm afraid. Just trying your suggestions TLE. Will get back to you in a minute. Cheers, John. |
TLE I can't thank you enough!!!!
Reset the tcp ip settings and bingo it's back on! Thank you so, so much! I'm almost crying tears of joy. ![]() Kind regards, John. |
| Thread Tools | |
| Display Modes | |
