Old 04-06-2011, 08:19 PM
AdamsAPlus's Avatar
AdamsAPlus AdamsAPlus is offline
AdamsAPlus is on a distinguished road
Default Laptop not working with battery in
I had a laptop come in the store. The Power Jack was broken. I found a new power board on ebay. I thought great I don't have to solder on a new jack. (Power Board was only $25)
I replaced the powerboard. I hooked it up. It powered on for about 3 min and then shut off. I unplugged it. Took the battery out. Then held the power button in for 30 sec. Then I plugged it in (battery still out) and was able to boot just fine.
So I shut it down. Put the battery in and tried to boot. It started to come on. Then the battery light flashed and it shut off. When it shut off there were no lights on at all. I left it alone for a few min and tried again. Same thing happened. I took the battery out and it booted just fine again.
With the battery in or out and plugged in, no lights come on at all until I try to power it on.
Do you think there is something wrong with the power board I got? Could it be the Battery Board?
This is an Acer Laptop. Sorry I do not have the model number on me right now. I can add it this evening if need be.
Adams A Plus Computer Repair and More
Hendersonville TN Computer Repair
CompTIA A+, CompTIA Net+, MCP, MCDST, MCTS: Windows Vista, MSITP: Enterprise Support
DCSE
Old 04-06-2011, 08:39 PM
usacvlr's Avatar
usacvlr usacvlr is offline
usacvlr is on the way
Probably bad cells in the battery.
You Break It. We Fix It!
http://www.usalaptoprepair.com
Old 04-06-2011, 08:44 PM
Martyn's Avatar
Martyn Martyn is offline
Administrator
Martyn has disabled reputation
Get a battery for a few £s on Ebay, looks like the supply is clamping down under a fault condition
Old 04-07-2011, 05:26 AM
AdamsAPlus's Avatar
New update. The battery seems fine. I will actually charge when the computer is turned off.
So here is what I tested. I charged the battery. Was able to turn it on. Battery in and adapter plugged in it only showed the battery. Would not charge and only run off the battery. I take out the battery while it is turned on and with it plugged in and it shut off. I unplug it and plug it back in (with the battery still out) and it comes back on. I have the little icon showing that it is running off the plug and no battery detected. I put the battery in (while still turned on) and it switches to battery mode but at the same time acts as if I unplugged it. Icon shows running off the battery and not plugged in. I'm at my wits end. I have had this laptop over a month and these people want it back. It took a while to get parts because the sender was real slow.
Oh and it's not the adapter because I have tried 3 different ones. All 19V and 3.42A
It's and Aspire 4720Z
DCSE
