Old 04-05-2011, 02:11 PM
pg07143's Avatar
pg07143 pg07143 is offline
pg07143 is an unknown quantity at this point
Default XP - Users home directory contents invisible
I have a PC (XP Home SP3) in which the customer used MBam to remove malware. The machine seems to be running fine, but there are missing (actually invisible) folders/files... The contents of the user's home directory appear to be missing if I look using windows explorer (totally empty). However, if I open a command prompt, I can navigate inside the folders and view files that don't show in explorer. Also, I only see two programs listed when I go to 'Start'->'All Programs' (FF and MBam).
Has anybody run into a similar situation? If so, how did you resolve?
TIA!
Scott
Old 04-05-2011, 02:25 PM
ZenTree ZenTree is offline
ZenTree will become famous soon enough
Had a virus recently which just made them hidden. You haven't said in your OP so I will ask, have you checked show hidden files (and even system files whilst we are at it)
Old 04-05-2011, 03:14 PM
pg07143's Avatar
I haven't checked for hidden files. I'll do that as soon as I get back home. Thx!
Old 04-05-2011, 04:03 PM
mraikes's Avatar
mraikes mraikes is online now
mraikes is a jewel in the roughmraikes is a jewel in the roughmraikes is a jewel in the rough
I've been using a little program called "unhide.exe". I just run it and walk away for a few minutes. When I come back, everything's visible again. Unfortunately I don't recall where I found it.
Of course you can do the same thing from the command line, something like "attrib -h -r -s /s /d c:\*.*"
Darn-Computer! Computer & Laptop Repair
Old 04-05-2011, 07:27 PM
mein's Avatar
mein mein is offline
mein is an unknown quantity at this point
I had a client with a virus that did this yesterday.
Unhide.exe can be found on bleepingcomputer.com
The problem is it will unhide all the files even those that should be hidden.
I carried out a system restore first to ensure the attributes were correct. Then did a full scan and removal of the virus.
Old 04-05-2011, 07:32 PM
SmithFamilyDesigns's Avatar
SmithFamilyDesigns SmithFamilyDesigns is offline
SmithFamilyDesigns is an unknown quantity at this point
I'm currently working pn a machine with this issue. System restore (if available) then remove virus, otherwise the attrib command above should be fine on the users folder (and all users for the start menu)
Sent from my HTC Vision using Tapatalk
"Never argue with a fool; onlookers may not be able to tell the difference."
http://www.SmithFamilyDesigns.com
Old 04-05-2011, 08:08 PM
mraikes's Avatar
This is true, but I don't know that it matters. I've never encountered any file that had to be hidden to work correctly.
Of course files are usually hidden only to keep end users from dinking around with them. But the odds of them deliberately digging into previously hidden directories and doing damage is pretty slim. Not impossible, but rare enough that I haven't had it occur.
Old 04-05-2011, 09:22 PM
mein's Avatar
I agree it's not critical, but I knew this customer would not understand why his directories now had files that didn't exist before. Just easier to get it as close to normal as possible.
  #9
Old 04-07-2011, 03:57 PM
AtYourService AtYourService is offline
AtYourService is on a distinguished road
I had 2 virus removals in this week that both had the same virus that hid the contents of c drive , i ended up just using attrib after i cleaned it out
  #10
Old 04-11-2011, 04:43 PM
Elemdee's Avatar
Elemdee Elemdee is online now
Elemdee is on a distinguished road
I've got one of these coming in tomorrow. Can't wait.
