Updating my BIOS
Well, I am thinking about updating my BIOS but what have I got to look out for when doing it? Could if I do the install wrong cause the whole computer not to boot up right? Ipodman |
Yes, flashing your BIOS improperly may cause the system not to boot. There are several ways to make sure it does work, though.
Some motherboards allow you to flash the BIOS from Windows itself. If yours does, do so - and make sure to make a backup image of your current BIOS version, simply as a precaution. Also, some boards have a Dual BIOS feature so in case the system crashes it will revert to the old BIOS version. If you have one of those, you made a wise investment. In case of a badly flashed BIOS, any of the following may happen:
Hope this helps. I realize it sounds like the "worst case scenario list", but in about 90% of the cases, it'll work without a problem. I had performed about 10 BIOS flashes so far and each and every one worked flawlessly. Good luck.
i think a good idea is to look up your brand of motherboard in the offical web site and download the update in the offical web site..Follow the instructions in the web site and you are done!
| Thread Tools | |
| Display Modes | |
