I have a client that has Mac 10.6 and I'm trying to setup a networked iR C3220.
To tell you the truth I've never set up a printer on a Mac before. So I click the + to add the printer I leave it on LPD and enter in the IP address of printer as for the queue name I've left it blank and put in a name then I go to select the driver. I've installed a PS and URFII driver but only the PS driver shows up so I select it. Then I check job accounting since they use it. I go to print something it asks for his ID then nothing and the queue just says sending 100% but never completes. I believe when I leave the queue name empty when setting up the printer it says that the printer is busy and will retry in 10 seconds. So what else can I try? Google comes up with vague answers and most are different since they apply to different versions of Mac
I'm a computer tech not a english major, that's why I have spell check. |
With Macs it says leave the queue blank but a lot of printers need a name defined to work. Stick print in there as a name and see how you go
Does it matter what I put in there? I put p1 (a google search someone suggested that) and I tried the name of the printer iR C3220 and it wouldn't work.
Also I forgot to mention it asks if its unidirectional or bidirectional. I think I tried both and it wouldn't work. What should it be?
System prefs/print&fax/+ sign/default tab/pick the printer/give it name if you want/done.
[FONT=Arial]ACMT[/FONT] Quote:
So you saying I shouldn't pic the canon driver and just leave it as the default PS driver?
I'm not a Mac expert by a long way so go with Anonymous Mac Tech. All I know is from my experiences installing printers on a few Macs is that some networked printers need a defined name i.e Canons are usually print or direct along with the ip address. I used to go out to them and because there was no name defined and Macs say leave it blank it won't work. So you can define it as a lpr printer, use the ip address and a name of print will normally work.
Edit Just had a look at what Anonymous Mac Tech said and this is what I was saying about some printers don't like that left blank, try print in that area(using lpr) and try then. edit again Just had a look at that particular model and the queue needs to be defined as LP.
Computer & Laptop Repairs Leighton Buzzard Virus Removal Leighton Buzzard Laptop Screen Replacement Leighton Buzzard Last edited by Martyn; 03-25-2011 at 03:15 PM. |
Yeah, pretty much...Even if the default print driver OSX gives you is out of date or for some strange reason incompatible, as soon as software update is ran it will find the print driver.
Ok I'll try that also. I didn't do it in the first place cause it needs to have job accounting turned on and didn't think the default would have that option so hopefully it will update and I can then turn it on.
#9
You are still completely missing the point. Just after you hit + to add a printer, up above the protocol drop down menu are four selections. They are default / fax / ip / windows. You are still trying to follow the ip setup to add a printer. Get off of ip and select default. After that you will your available printer list.
#10
| Thread Tools | |
| Display Modes | |
