Go Back   Technibble Forums > Technical Discussions > Hardware
Old 02-26-2011, 12:38 PM
tarik tarik is online now
tarik is an unknown quantity at this point
Default strange problem with shutting down
ok strange problem with a customers pc.
pc shuts down almost as soon as we get into windows vista.
pc will work and run fine in safe mode.
we have checked and swapped power supplies, ram, hard drives and graphics cards all to no avail.
only thing i havent done yet is reformat but i dont believe thats the case as it happens even when i unplug the hdd and boot from a ubuntu live cd.
Have also checked all the bios settings and all seems fine.
im starting to think it could be a bad motherboard?
Old 02-26-2011, 12:42 PM
KompuKare's Avatar
KompuKare KompuKare is offline
KompuKare is on a distinguished road
Send a message via MSN to KompuKare Send a message via Skype™ to KompuKare
I assume you have tried shutdown -a?
A shutdown sounds more software to me, a reset or even instant power off is more likely to be hardware.
Old 02-26-2011, 12:44 PM
yes sorry tried that i mean an actual switch off of the pc as if power was being cut.
Temperatures are all fine and low, have also applied more thermal compound and cleaned any dust from case.
Old 02-26-2011, 12:49 PM
MobileTechie's Avatar
MobileTechie MobileTechie is online now
MobileTechie will become famous soon enough
If it works in safe-mode then I don't see how it could be h/w
Old 02-26-2011, 12:53 PM
Martyn's Avatar
Martyn Martyn is online now
Administrator
Martyn has disabled reputation
Was just putting that
this is what i was thinking originally, but then when i disconnected everything and tried booting into ubuntu same problem. computer just switches off before its even loaded.
Old 02-26-2011, 12:55 PM
Martyn's Avatar
Administrator
If I was going to try any hardware I would whip in a psu to test. It wouldn't explain why safe mode would work but would rule it out. Maybe you just got lucky with safe mode. Is it consistently doing it in each mode eg safe mode always ok, normal mode not, Ubuntu not?
Old 02-26-2011, 12:57 PM
changed psu already, no change
  #9
Old 02-26-2011, 12:58 PM
Martyn's Avatar
Administrator
Sorry didn't see that.
  #10
Maybe working in safe mode was a one off? If not then why that happens would be interesting.
Do the logs give anything away? I.e. is the same event being logged before each shut down?
