Go Back   Technibble Forums > General Computers > Guides, Tips and Tricks
Old 01-26-2011, 11:41 PM
Jared Jared is offline
Jared is an unknown quantity at this point
Default Staple ethernet cable idea
Instead of buying coax staples which need to be hammered in, why not just put down a regular staple with a staple gun, then fasten your ethernet cable to it with a cable tie? Just saved me a few minutes while working for a customer, and I thought I would share.
Huntingdon PA Computer Repair
Old 01-26-2011, 11:43 PM
mjbasford mjbasford is offline
mjbasford is an unknown quantity at this point
i use a staple gun and staple my wire directly with that. Just make sure the staples are long enough or they will damage the wire. Also, only works with one wire at a time if you are trying to to multiple.
Brand i use is: Arrow T25 9/16" (14mm)
Old 01-26-2011, 11:51 PM
iptech iptech is offline
Banned
iptech is on the way
Why not just buy a regular cable staple gun that's specifically designed for the job?
I use one of THESE.
Old 01-27-2011, 12:16 AM
that's similar to what i was referring to, but for convenience i can buy more staples at the local lowes
Old 01-27-2011, 12:39 AM
ATS's Avatar
ATS ATS is offline
ATS is an unknown quantity at this point
That's the same thing I do, staple gun with long staples.
I like the idea of using cable ties on the staple, I'll keep that in mind if I'm running multiple cables.
Old 01-27-2011, 12:59 AM
dipper dipper is offline
dipper is an unknown quantity at this point
Great idea. I would have thought that just using a staple may damage the cable. Using a cable tie though gets around this potential issue.
Old 01-27-2011, 01:07 AM
Just thought I would share. I do have a staple gun that can do that, but I always end up putting staples through my cable :-(
Also, this works especially well for multiple cables.
Old 01-27-2011, 01:18 AM
TopLevelComp TopLevelComp is offline
TopLevelComp is on a distinguished road
Send a message via AIM to TopLevelComp Send a message via Skype™ to TopLevelComp
Why not use these?
http://www.actfs.com/CatalogProducts.asp?nProductsID=95
  #9
Old 01-27-2011, 04:18 AM
dbdawn dbdawn is offline
dbdawn is on a distinguished road
Originally Posted by TopLevelComp View Post
I have used something similar before with strips of velcro or zip ties, works pretty good if you have to run more than one cable.
  #10
Old 01-27-2011, 01:29 PM
Titan-vds Titan-vds is online now
Titan-vds is an unknown quantity at this point
I agree with TopLevel. Easier when you run more cables.
