Go Back   Technibble Forums > Technical Discussions > Security, Viruses and Trojans
Old 01-15-2011, 09:01 PM
MobileTechie's Avatar
MobileTechie MobileTechie is online now
MobileTechie will become famous soon enough
Default Hitman persistently finding proxy
I have a laptop in which had a fake AV infection. This was dealt with but Hitman kept finding an infected file and a proxy set on a 127.0.0.0:8074
I've checked it out with the usual array of AV tools like MBAM, SAS and Hitman and TDSSKiller. I reset the MBR both using MBRCheck and then again offline. Manual investigations with tools like Kernel Detective and Malware Defender and Autoruns have found no startup entries but a few inconclusive kernel hooks. Sigverif was finding an unsigned driver but not anymore. Offline scans found a rootkit and a trojan which were removed.
The system seems to be running absolutely fine and there are no redirections going on. No virus scan finds anything. Various MBR checkers come up clean. However, Hitman still claims IE is connecting to the internet via the 127.0.0.0:8074 proxy after each reboot. There is no sign of this proxy in Internet Options or in the related registry keys.
I'm trying to work out whether the infection is still present or whether this is a Hitman Pro bug.
Old 01-15-2011, 09:16 PM
Martyn's Avatar
Martyn Martyn is online now
Administrator
Martyn has disabled reputation
Do you mean 127.0.0.1:8074 MT? There is reference to it in this link
http://forums.malwarebytes.org/index...howtopic=71871
You could run Wireshark and see if there is an ip of that address and port?
Old 01-15-2011, 10:06 PM
iisjman07's Avatar
Have you performed offline virus scans? You mention the machine had a rootkit, a part of me is thinking it (or another) could still be there
Old 01-15-2011, 11:02 PM
TopLevelComp TopLevelComp is offline
TopLevelComp is on a distinguished road
Send a message via AIM to TopLevelComp Send a message via Skype™ to TopLevelComp
do they have Gadu-Gadu installed?
Also check this in the registry:
HKCU\Software\Microsoft\Windows\CurrentVersion\Int ernet Settings,ProxyServer = http=127.0.0.1:8074
Old 01-15-2011, 11:29 PM
As stated, I've done offline scans and they are now clean, and no proxy registry keys exist.
Martyn: yes sorry I meant 127.0.0.1 - no sign of that port being open according to wireshark or TCPview
Old 01-16-2011, 01:48 AM
arrow_runner's Avatar
arrow_runner arrow_runner is offline
arrow_runner is an unknown quantity at this point
Send a message via AIM to arrow_runner Send a message via MSN to arrow_runner Send a message via Yahoo to arrow_runner
Try running hijackthis. I know that even after I clear out that proxy field in IE, hijackthis still finds it in the registry.
Old 01-16-2011, 01:56 AM
BigMac BigMac is offline
BigMac is on a distinguished road
I have seen this on several occasions. If you search the registry, you will find it and can delete the key. I can't remember the exact location in the registry, but my guess is that the malware not only puts the proxy in the current configuration, but it also puts it in IE's "default" settings. Therefore if you attempt to reset IEs settings (under the advanced tab) it will still have the proxy in place. This is just a guess and I have not tested it though.
Old 01-16-2011, 03:59 AM
stevenamills stevenamills is offline
stevenamills is on a distinguished road
Every time I have seen this it's in the Internet Options settings.
Internet Options - Connections - Lan Settings - Advanced
The Advanced button will be greyed out, but check the "use proxy" box to make it active. I'll bet you find the port on the server list.
Steve
Fox Valley Computer Services
Trying desperately to make a living in a failing industry in a failing economy.
  #9
Old 01-16-2011, 08:05 AM
As I said in the OP, I already checked the registry and IE's settings. There is no proxy set there. Therefore you won't be surprised to hear that tools like OTL or HJT don't find proxy settings either.
The only tool that finds the setting is Hitman Pro.
