Old 12-31-2010, 01:20 AM
phaZed's Avatar
phaZed phaZed is online now
phaZed is a jewel in the roughphaZed is a jewel in the roughphaZed is a jewel in the rough
Default STRANGE: Only IDE mode will boot Windows XP, not AHCI
Here's a strange problem,
Netbook, Acer Aspire ONE AOD250
One day, out of the blue this computer stops loading windows XP SP3. The loading screen appears with the status indicator, but simply does not load. Hard drive activity stops precisely as the WiFi light appears (and blinks). I have waited over an hour.
Safe mode works fine, SM w/ Networking works as well.
A scan with Malwarebytes and SUPERAntiSpyware have been performed with nothing more than a few tracking cookies. I don't believe this problem is Virus related, but performed the scans anyway. TDSS Root kit revealed nothing.
I have disabled devices such as Wifi, NIC, Sound, etc... and tried to start normally. All drivers have been reinstalled, checked, or updated. The BIOS has been updated. The Intel Matrix storage manager has been removed and reinstalled. All NO-GO.
OK, so let's repair Windows right? Hook up the external USB DVD drive with WinXP SP3, it loads and then Windows reports that no hard drives were detected. I know this system doesn't need any extra drivers. So, now I stick in the XP install USB memory stick that I have used previously many times and the system reports it cant find bootmgr (or NTLDR, because I tried BOTH types). Now I have to try something else. I changed the SATA controller from AHCI to IDE in the BIOS, and windows will boot slowly (10 mins to user profiles), but it boots! My XP USB drive and USB DVD also WORKS in IDE mode, and both the DVD XP install and USB XP install see the hard drive!
Also, I was able to get into recovery console, and replaced the kernel32.dll with one from the XP install. I changed the BIOS back to AHCI and windows BOOTS ONE TIME, then fails after subsequent boots. WTF!
So, the Hard drive or HD Controller essentially works in IDE mode, and not in AHCI mode. I have my bet on a failing Intel SATA controller, but if that were the case, why would a kernel32.dll replacement cause perfect operation ONE TIME?
What do you think? Any suggestions? I'm almost out of tricks here!
[EDIT]
Forgot to say that Windows logs, and Boot logging didn't result in any significant finds. Error logs in Windows only report DCOM service not started (Because of Safe Mode).
MBR has been re-written, and CHKDSK passed too. MemTest86+ Also completed 4 passes..
[/EDIT]
Sincerely,
Aaron H.
Aaron Heidlebaugh
Computer Technician / Owner
www.AaronsPCSupport.com
804-307-4465 (Call or Text)
Laptop LCD repair | DC Power Jack Repair | Virus Removal
Desktop Repair | Hardware | Software | Troubleshooting
Old 12-31-2010, 01:48 AM
geekhelp4u's Avatar
geekhelp4u geekhelp4u is offline
geekhelp4u will become famous soon enough
Send a message via Skype™ to geekhelp4u
Its a long shot but try this reg fix and also make sure you have IaStor.sys located at C:\Windows\System32\drivers\
Code:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\CriticalDeviceDatabase\pci#ven_8086&dev_2922&cc_0106]
"Service"="iaStor"
"ClassGUID"="{4D36E96A-E325-11CE-BFC1-08002BE10318}"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor]
"Type"=dword:00000001
"Start"=dword:00000000
"Group"="SCSI miniport"
"ErrorControl"=dword:00000001
"ImagePath"="system32\\drivers\\iaStor.sys"
"tag"=dword:00000019
"DisplayName"="Intel AHCI Controller"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters]
"queuePriorityEnable"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Enum]
"0"="PCI\\VEN_8086&DEV_2922&SUBSYS_B0051458&REV_02\\3&13c0b0c5&0&FA"
"Count"=dword:00000001
"NextInstance"=dword:00000001
Chris Pfeffer
Military: United States Army Communications and Networking Specialist
Civilian: Service Desk Team Lead
http://www.geekhelp4u.com
Old 12-31-2010, 02:10 AM
phaZed's Avatar
Hey Chris,
Thanks for the hail mary, and good thinking. However, the registry is identical to what you have in your post (minus the vendor #'s of course), also iaStor.sys is in place, and the size/date are in order as well.
Here are some more clues:
Boot in IDE mode:
SafeMode does not work (quick bluescreen)
Regular Boot does work
Boot in AHCI mode:
Safemode does work
Regular mode does NOT work
I think I am going to try a Nuke n Pave after I make a drive image.
Sincerely,
Aaron H.
Aaron Heidlebaugh
Old 12-31-2010, 02:25 AM
ajc196's Avatar
ajc196 ajc196 is offline
ajc196 is an unknown quantity at this point
Turn on AHCI in the system first. Then slipstream the SATA driver pack into an OEM XP disc with DPBase and nLite, then run a repair installation.
http://driverpacks.net/driverpacks/w...-storage/10.11
http://driverpacks.net/applications/latest
http://www.nliteos.com/download.html
Old 12-31-2010, 03:17 AM
phaZed's Avatar
ajc196,
That may have worked, but it's too late to tell now
I found this http://ezinearticles.com/?How-To-Rep...very&id=794500
ACER has a recovery partition of which the BIOS checks at boot, and does some magic with a custom MBR. The above instructions seemed to have fixed the MBR to allow the recovery partition to become accessible by pressing ALT+F10 at BIOS. This did not fix the Windows partition, but the Manufacturer recovery partition worked fine. Also, to clear any suspicion, the recovery partition was unavailable before I wrote a standard MBR with recovery console.
The system has now been recovered, and is in a stock state (Which the customer is now requesting - guess those POGO games weren't that important after all ).
Thanks for all of your help everyone.
Sincerely,
Aaron H.
Aaron Heidlebaugh
Old 01-04-2011, 09:19 PM
shfire2000's Avatar
shfire2000 shfire2000 is offline
shfire2000 is an unknown quantity at this point
I have updated a few PC's to AHCI. Find and install the manufacturers AHCI drivers before switching the BIOS settings. For Vista and Win 7 check/ change the following registry settings from Microsofts KB 922976:
  1. Exit all Windows-based programs.
  2. Click Start, type regedit in the Start Search box, and then press ENTER.
  3. If you receive the User Account Control dialog box, click Continue.
  4. Locate and then click one of the following registry subkeys:
  5. HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\Msahci
  6. HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servic es\IastorV
  7. In the right pane, right-click Start in the Name column, and then click Modify.
  8. In the Value data box, type 0, and then click OK.
  9. On the File menu, click Exit to close Registry
With Vista SP1 or any windows version after you should be ok after that to change the BIOS and the computer should boot up fine. You will need to what ajc196 said for any versions prior to Vista SP1.
Old 01-06-2011, 05:09 AM
XFalloutX XFalloutX is offline
XFalloutX is an unknown quantity at this point
Just a side note
I actually had a update change the AHCI settings and cause the computer not to work unless you switched it back. Only happend once.
I'm a computer tech not a english major, that's why I have spell check.
