Old 12-16-2010, 03:28 PM
arrow_runner's Avatar
arrow_runner arrow_runner is offline
arrow_runner is an unknown quantity at this point
Send a message via AIM to arrow_runner Send a message via MSN to arrow_runner Send a message via Yahoo to arrow_runner
Default Service Pack 1 Infinite Reboot, not the normal one
This isn't the normal 'step 0 of 3' reboot loop.
Story: Laptop came in with a virus. It also had an Acronis Secure Zone partition. Vista had practically no updates.
I got the virus off and the laptop is running fine. I move into the updates. Start SP1, finishes, reboots. Now Vista 'normal mode' just flickers and reboots immediately. Turning on boot logging does nothing as the restart is practically immediate. At this point I took an image backup and noted that there were no system restore points, yay...
Safe mode gets to pshed.dll and then the screen flickers and reboots.
The vista recovery console on the HD just keeps looping if you select it, as in it takes you right back to the same dos type menu you were just at.
Things I've tried:
Last Known Good Config
Restoring the registry from the regback folder
Bootrec /fixboot and bootrec/fixmbr
Removing the acronis partition and resizing the C: drive (couldn't hurt, since I have an image now)
Google till my back hurts
Any ideas?
Old 12-16-2010, 03:41 PM
ljtechservices ljtechservices is offline
ljtechservices is on a distinguished road
Send a message via Skype™ to ljtechservices
I've had a 2 Vista issues similar to this the past week.
Usually a boot into safe mode and rebooting will fix or safe mode + restore to a previous point will work.
Then when another MS update goes through it quits booting.
I'm wondering if it's something with vista.
Computer 1 hadn't had an update in 2 years.
Computer 2 received frequent updates but failed on the last one this morning.
Old 12-16-2010, 10:09 PM
AdamsAPlus's Avatar
AdamsAPlus AdamsAPlus is offline
AdamsAPlus is on a distinguished road
Try to get a hold of MSDaRT 6.0 and do a Start Up Repair. I have seen this and that worked for me. Well once it did. Another time I had to Nuke and Pave.
You can get MSDaRT from Torrent sites if your not a member of Microsoft's TechNet.
Old 12-16-2010, 11:59 PM
Ccomp5950's Avatar
Ccomp5950 Ccomp5950 is online now
Ccomp5950 will become famous soon enough
Things I've tried:
Any ideas?
Boot to a boot CD and check C:\Windows\System32\Drivers\ for 0 size drivers, if so, rename them.
Old 12-17-2010, 12:22 AM
Knightsman's Avatar
Knightsman Knightsman is online now
Knightsman is on a distinguished road
Remove the hard drive from the customers computer, attach it to a computer that has “unlocker tool” installed.
Go to C:\Windows\WinSxS\. Look for Pending.xml. Delete this file using the “unlocker tool”.
You may be able to delete it without using this tool, depending on the file permissions.
Old 12-17-2010, 12:24 AM
Knightsman's Avatar
oh wait. hmm, bad hd? bad hardware?
Old 12-17-2010, 12:51 AM
No. It worked fine before SP1 and it is working as I used a factory restore, although I will try the ERD with the image on a spare hard drive just to see what it will do.
Also, that unlocker is to get out of the 'installing update 0 of 3' loop, right?
Old 12-17-2010, 01:23 AM
loaner's Avatar
loaner loaner is offline
loaner is an unknown quantity at this point
yep....deleting "pending.xml" will get rid of downloaded updates that finish installing on reboot. I just didn't mention it because the original op said that it wasn't due to the 0 of 3 problem. BUT, the problem didn't start until after the update. I'd get rid of pending.xml and retry the update.
"Computers are incredibly fast, accurate and stupid; humans are incredibly slow, inaccurate and brilliant; together they are powerful beyond imagination." -- Albert Einstein
  #9
Old 12-17-2010, 01:27 AM
Knightsman's Avatar
sorry, the its called the "unlocker tool" YOu can download it, but download 1.8. It will unlock it even without permissions and allow you to delete the file. If its there, but your problem sounds different than this.
  #10
Old 12-17-2010, 01:28 AM
Knightsman's Avatar
Have you tried a repair install?
