I take an Acronis image of my client's HDD before I begin a virus removal process, or a migration, etc. But lets say I need to restore that image back to the HDD or another HDD: what about the viruses inside? Should they be cleaned out of the image itself before restoring it? Is this as thorough/reliable as doing a regular virus scan while windows is running?
If you restore the image, the OS will be just as infected as it was before you took the image. You can then do a regular virus removal, or backup and reload.
If you can mount the image on your own machine so that it appears as a readable and writable slave drive, you can use scanners that work with slave drives, and remote registry tools. If Acronis can do this, let me know. I know you can use Acronis to view the contents of an image and extract files/folders, but if you can also delete them, you might be able to tell what to delete by name and date. You can't get registry entries easily this way, and it isn't so reliable with the tricky infections, but it's the fastest way with easy infections. I'd stick with option 1, and avoid modifying images. |
u make an image before you do you virus removal work just in case duing the removal process the system crashes even more or worse you can always put the system back they way it was before you touched it. after you sure you cleaned the system do another clean image??
No more than mounting a physical disc as a secondary drive in a clean system. So long as you're not running any files off of it and are only analyzing them, there's no risk.
Xander St Catharines Computer Repairs New here? Watch this and read this. Remember, it's not our problem, it's yours so ask your questions well. |
| Thread Tools | |
| Display Modes | |
