Old 11-27-2010, 09:02 PM
ugotdave ugotdave is offline
ugotdave is an unknown quantity at this point
Default Write Protect Flash Drive
Ok,
How are all of you write protecting your flash sticks?
I saw a reg hack that modified the "HKEY_LOCAL_MACHINE" hive, but I was never able to find this reg Key "StorageDevicePolicies" on XP machines.
I saw some are using "SDHC unlocked" but I can not seem to find this utility. Is this a SanDisk util?
Old 11-27-2010, 09:04 PM
Appletax's Avatar
Appletax Appletax is offline
Location: Gladstone, MI (In Michigan's Upper Peninsula)
Appletax will become famous soon enough
https://www.kanguru.com/index.php/fl...ru-flashblu-ii
Old 11-27-2010, 09:12 PM
Martyn's Avatar
Martyn Martyn is offline
Administrator
Martyn has disabled reputation
i have one of these
http://www.pqi.com.tw/product2.asp?cate1=18&proid=13
Old 11-27-2010, 09:50 PM
14049752 14049752 is offline
14049752 is on a distinguished road
Originally Posted by ugotdave View Post
Ok,
The reg key would have to be done on every system you plug it into.. don't bother with that.
I think "SDHC unlocked" is just an SD card, with a usb adapter, and using the write switch on the sd card. It's not a software utility.
Basically, it comes down to the fact that you need a write protect switch on either a flash drive or on the sd card. Software is not a solution.
Old 11-27-2010, 10:29 PM
Xander's Avatar
Xander Xander is offline
Xander has a spectacular aura aboutXander has a spectacular aura about
FYI: I bought a few cheap SD/SDHC adapters so that I could use my locking CD card. Took me a few uses to notice that the lock did absolutely nothing in one of the adapters; it somehow overrode it and it was writeable regardless of the lock's position.
An SD-adapter is a great tool but test it on your own system before plugging it into a virus-ridden one.
Old 11-28-2010, 12:57 AM
lebpcmedic lebpcmedic is offline
lebpcmedic is an unknown quantity at this point
Ok,
Windows 7 Ultimate has a feature called Bitlocker To Go which basically makes the usb drive encrypted as well as read only on foreign machines.
http://blogs.techrepublic.com.com/wi...indows/?p=1176
Old 11-28-2010, 01:36 AM
gazza gazza is offline
Banned
gazza can only hope to improve
Just use one of these with a SD card that has a write lock on it. I have never had any problems,to easy!
http://cgi.ebay.com.au/2x-SD-SDHC-CA...item255ecbbd67
Old 11-28-2010, 03:32 AM
Thanks everyone for your input.
As mentioned by Appletax and Martyn, I think I will get one of the Kanguru or Pqi sticks that has a tangible write lock switch on it. Kanguru has a 16GB for about $45, not a bad price. But I will also check to see which one has the fastest memory.
  #9
Old 11-28-2010, 05:40 AM
PR Tech PR Tech is offline
PR Tech is an unknown quantity at this point
We only use Kanguru drives in our shop and they all have copies of our "tech tools" loaded onto them. We have never had an issue with any of them so far. They are rock solid flash drives with locking switch to prevent viruses from doing what they do best.
www.PasoRoblesTech.com
  #10
Old 11-29-2010, 02:09 AM
SnoSalmon SnoSalmon is offline
SnoSalmon is an unknown quantity at this point
Have been looking for this myself.
I think I will purchase a few 4gb sticks and chuck my tech tools onto them. If one gets chewed up I won't lose sleep as I have a backup to keep me going while I sort the first.
Haven't seen a usb stick with a switch since the 64mb stick days around these parts...
