I found this little tip & thought I should share..
Problem: The wireless connection is off when you start Windows on Fujitsu-Siemens Amilo laptop Solution: Make sure you have "Launch Manager" installed, this can be found on the Fujitsu Siemens Driver site. Then in Notepad copy the following: Code:
Set WshShell = WScript.CreateObject("WScript.Shell")
Set oExec = WshShell.Exec("C:\Program Files\Launch Manager\WisWBSet.exe")
do while WshShell.AppActivate("Wireless Status Option")=False
WScript.Sleep 100
loop
WScript.Sleep 100
WshShell.sendkeys("{TAB}{TAB}{LEFT}~")
Copy a short cut of the .vbs file and drag it into your "Start Menu / Programs / Startup" to ensure it starts automatically when rebooting. Source: http://www.evrim-sen.com/html/amilo-wireless-status.htm |
I have used this script on a few Amilo laptops. It works very well. I still think it's very strange to have Wi-Fi turned off by default with no way for the end user to change it.
| Tags |
| fujitsu, siemens, startup, wireless |
| Thread Tools | |
| Display Modes | |
