Old 11-02-2010, 06:38 AM
hondablaster's Avatar
hondablaster hondablaster is offline
hondablaster is on a distinguished road
Send a message via AIM to hondablaster
Default VPN question.
Ok so I have a VPN on my monowall router (linux router) the vpn works but I'm trying to understand the benefit other then being encrypted between me and my home router when I am at Starbucks or a free wifi spot.
I was under the impression that I would have full access to my subnet when I am not at home. So far I can't do anything other than forward my home IP to my location via the VPN tunnel.
In the future I would like to be able to lock into my PPTP VPN on my router from outside, and see all my network hardware, (printer, PCs, VOIP phone) with a local IP address which is my case is 192.168.77.0 /24. Why is this not working?
When I do ipconfig while on my VPN i get 192.168.77.0 255.255.255.255 why is this I cannot find the answer on google. I can force it to a different IP but I still cannot get rid of the odd subnet mask.
Basically can I, or can't see my devices using local IP or Netbios names when on the VPN?
CompTIA A+, N+ Certified, Microsoft Desktop Support Technician. http://www.sd-techblog.com
Old 11-02-2010, 04:48 PM
onetech4all's Avatar
onetech4all onetech4all is offline
onetech4all is an unknown quantity at this point
Default Re:
When you dial into work, you need to get an internal IP address that will allow you to browse the network. You probably need to specify the internal DHCP server, so that when your laptop (I am guessing) dials-in, you receive an internal IP address. Your router needs to know how to locate the DHCP server.
If you do an ipconfig /all, do the results you get match the home infrastructure (DNS, WINS, etc)?
(A+, Network+, Server+, MCSE 2003, VMware trained)
Corona CA I.T. support for businesses
"If you don't make mistakes, you don't make discoveries."
"Do what you love and you won't work a day in your life."
"Do you work to live, or do you live to work?"
Old 11-02-2010, 04:49 PM
Default Re:
Also, what client are you using to dial into your home?
Old 11-02-2010, 05:52 PM
thecoldone06's Avatar
thecoldone06 thecoldone06 is offline
thecoldone06 is on a distinguished road
is this the software you are using to setup your VPN? I just googled monowall and found that. If it is, in the middle where it says "remote address range", what address is in there?
Old 11-02-2010, 07:16 PM
mjbasford mjbasford is offline
mjbasford is an unknown quantity at this point
edit:: misread
OP: on your home pc that hosts the vpn, enable ics between the vpn and the lan adapter
Old 11-02-2010, 08:24 PM
Ill be on later tonite to give more details. Yes Coldone that is the screen. Ill be back.
Thanks
Old 11-06-2010, 07:10 PM
Hello all again.
I figured it out, well actually it figured itself out. I just got frustrated and unplugged my router(actually its a PC with two nics) and plugged it back in and it worked fine. Also I was pinging one of my PCs with ICMP off (public firewall mode) which made things seem like it wasn't working. So far everything works and I am so excited.
My next project is really simple. To print remotely and my printer prints it out!
Everyone home should have a VPN.
