I thought it was the PSU but I have tested it and even tried it in another machine and it works perfectly.
The motherboard LED comes on but when I press the power button its completly dead. So its either:- Dead motherboard Dead switch Normaly I could just short the pins on the power header but being a dell all the case lights/button are on a ribbon cable and I have no idea what to short without stripping everything down and tracing the cable, even then its going to be very tricky to do. Is their a simpler way I can force the PSU to power on with the main 24-pin header connected to the motherboard? |
The 5100 along with the E510 are notorious for having this problem. Browse the Dell forums - there are hundreds of posts discussing this. In fact, you may be overwhelmed with the sheer number of posts.
Jump the green and a ground to start it. A little risky to leave it plugged into the board though if there's a short. But you know how it is: no guts, no glory.
| Thread Tools | |
| Display Modes | |
