Old 09-04-2010, 10:55 AM
BCC BCC is offline
BCC is an unknown quantity at this point
Default replacing hdd on Advent 5712 laptop?
has anyone got any links or guides or ideas on how to replace the hard disk drive in this lappy? I can see it underneath the hdd cover but it seems to be connected under the chassis somehow & I can't see how or where to take it apart, I've searched the net for hrs....
Thanks in advance of any help
BCC
Old 09-04-2010, 11:15 AM
TLE's Avatar
TLE TLE is offline
TLE is on a distinguished road
Might be worth posting a picture of the hatch so that people can see it.
Old 09-04-2010, 02:20 PM
BCC BCC is offline
yea, good idea, will do !
thnx, bcc
Old 09-04-2010, 02:46 PM
joydivision's Avatar
joydivision joydivision is online now
joydivision will become famous soon enough
I've seen a few where you have to remove the keyboard to get to the HD caddy so its probably that.
Old 09-06-2010, 07:45 PM
BCC BCC is offline
Default pics of hard disk in-situ
Many thanks for your replies...
Luckily, well kinda, we did a raw-copy of the drive to another hdd & went to remove the drive & that's when we realised it's not as easy to remove as usual... it's turning out to be an absolute nightmare... & now very urgent that we get the hdd out of it's chassis & replaced.... because in our wisdom....... we decided to carry on with the 'tune-up' work on the orig drive... & all was going well until we came to do the Vista SP2, didn't work & got as far as doing step 3 of 3 0% & now that's all it'll do.... so we really need that drive replaced & back to square 1...
I've uploaded the following pics in the desperate hope that someone can shed some light on how the heck the hdd comes out.... please!
Old 09-06-2010, 08:49 PM
Charlotte PC Charlotte PC is offline
Charlotte PC is an unknown quantity at this point
There are typically 2-4 screws holding chassis in. I think I can see two on the bottom of your picture. Remove the screws and pull the drive using the plastic tab. Should come out.
http://www.charlottepcworks.com
Old 09-06-2010, 08:58 PM
iptech iptech is offline
Banned
iptech is on the way
Remove the screws holding the HDD chassis to the laptop frame and lift the end facing the front of the laptop slightly so you can slide the drive back off the SATA interface.
Old 09-06-2010, 09:33 PM
loaner's Avatar
loaner loaner is offline
loaner is an unknown quantity at this point
this may not help at all, but....
vista has a file that holds the "reboot after update" info. I can't recall the file name, but maybe someone can call it out. i repaired a good friends laptop simply by deleting this file. after deletion, just started updating again and all went well.
it's named something like winsys.something....sorry, but i can tell you it's an .exe file.
....goss
"Computers are incredibly fast, accurate and stupid; humans are incredibly slow, inaccurate and brilliant; together they are powerful beyond imagination." -- Albert Einstein
  #9
Old 09-06-2010, 09:43 PM
Banned
....goss
Use boot medium or Vista / Windows 7 Rescue Disk. From command prompt navigate to C:WindowsWinSxS. Delete "pending.xml". Reboot and enjoys the wonders of Vista.
That said, it'll be useless is physically removing a hard drive from a laptop.
  #10
Old 09-06-2010, 09:52 PM
loaner's Avatar
That's it....
you pulled that one out of your a$$ didn't ya iptech....nice job.
...goss
