Old 08-23-2010, 12:10 AM
HubCityPC's Avatar
HubCityPC HubCityPC is offline
HubCityPC is an unknown quantity at this point
Send a message via Skype™ to HubCityPC
Default Changing Vista retail disc to an OEM?
Hey guys I'm in need of a little help or a point in the right direction.
I have a customer with a Vaio laptop that was severely corrupted. After wasting quite a bit of time on it, I decided to nuke and pave. It's a few years old anyway and could use a refresh. This computer does not have a recovery image on the drive and the customer does not have his physical OS disc.
I'm a Technet subscriber and figured no problem, I'll just d/l the ISO, change it to an OEM version and nLite a new image. This is the first time I've tried doing that with anything newer than XP and well....there's no setup.ini file to edit.
I Googled around and found a few guides but I'm not so confident in the sources. Has anyone successfully done this and if so, could you point me to a reliable online guide or sum up the process here?
While researching I did discover that nLite won't work with Vista but I have already d/l and installed vLite.
Any help would be appreciated!
Thanks,
Kevin
Old 08-23-2010, 12:13 AM
myPCTechs myPCTechs is offline
myPCTechs is an unknown quantity at this point
Unhappy
What brand OEM is it? Dell, HP, etc. If I remember correctly, each OEM install now since Vista has their own product key allotment and you must have the correct OEM install to match the key. We tried installing a Dell OEM to an HP one time, for example, and the key failed.
The easiest way for us to handle this problem in the past was to download the correct OEM, or in some cases locate a tech who had a copy.
Old 08-23-2010, 12:24 AM
HubCityPC's Avatar
It's a Sony Vaio. I grabbed the key off the machine using a portable app and it did not match what was on the COA on the bottom of the laptop.
I just ran across this and I'm wondering if this will work??? The article seems to talk only about Windows 7.
Kevin
Old 08-23-2010, 01:10 AM
arrow_runner's Avatar
arrow_runner arrow_runner is offline
arrow_runner is an unknown quantity at this point
Send a message via AIM to arrow_runner Send a message via MSN to arrow_runner Send a message via Yahoo to arrow_runner
I'm definitely interested in what you find. Keep us updated!
Old 08-23-2010, 01:27 AM
dogskool dogskool is offline
dogskool is an unknown quantity at this point
I haven't used these guys, but I almost did:
http://www.restoredisks.com/default.aspx
I was able to order the restore disk directly from Sony.
Old 08-23-2010, 03:54 AM
ajc196's Avatar
ajc196 ajc196 is offline
ajc196 is an unknown quantity at this point
You're over-thinking it. Retail Vista discs are able to use both retail and OEM keys. So nothing at all has to be changed. I've never tried an upgrade key, so I dunno about that though.
On TechNet, I believe the image is just listed out as Windows Vista with SP2 (the iso is Vista Ultimate retail). Just get that in x86 and x64 flavors, and you're good to install with any version's key, OEM and retail both.
EDIT:
Oh, just saw you linked to my previous post... item 2 mentions the same thing I just said about Vista Ultimate retail being able to install any version, OEM or retail.
ALSO:
The product key on the COA is what you want to use. Most of the time, the key in the system will not match the COA because the drives are mass-imaged at the factory. Therefore, the key you grab from the originally-shipped OS has (I'd guess) a 5% chance of actually activating.
Old 08-23-2010, 05:24 AM
JRDtechnet JRDtechnet is offline
JRDtechnet is on a distinguished road
All Vista dvds have all the versions even if it says Home Premium you can still install Ultimate from it. And it will install and activate with any key, I use my MAPS Vista dvd to do reinstalls using the COA on the computer. You just have to pick 32-bit or 64-bit retail COAs will activate with both, but OEM's won't.
Computer Repair NJ
Old 08-23-2010, 09:02 AM
swaddo's Avatar
swaddo swaddo is offline
swaddo is an unknown quantity at this point
I dont have to reinstall many vista machines from scratch (most times I can recover the restore parition), but i recently had some trouble putting vista back on a couple of toshiba notebooks (L300) using a retail Vista Home Premium disk. In both cases it would not accept the key on the COA.
Is it only the ultimate disks that work with all keys?
  #9
Old 08-23-2010, 09:09 AM
TLE's Avatar
TLE TLE is offline
TLE is on a distinguished road
nLite doesn't work with Vista, so you will have to download vLite instead. Bear in mind it only supports slipstreaming of SP1 and not SP2.
Note to self-read all of post before replying...doh!!!
  #10
Old 08-23-2010, 12:02 PM
HubCityPC's Avatar
Thanks for the input guys but it seems like a few techs have different opinions or experiences.
I have tried Vista x64 Home Premium and Ultimate discs and used the COA on the bottom of the laptop. It accepts the key during setup but once the install is complete it will not activate.
So am I understanding correctly that using a retail Vista x64 Ultimate ISO should work?
For those mentioning the fact that you can use a Vista ISO to install any version of the OS, I understand that and yes, it does indeed work. That much I was aware. The issue is the flavor of the ISO i.e. Retail vs. OEM and what key it will accept.
Thanks again,
Kevin
Tags
oem, setup.ini, vista, vlite
