Old 08-10-2010, 01:58 AM
FoolishTech's Avatar
FoolishTech FoolishTech is online now
FoolishTech is a jewel in the roughFoolishTech is a jewel in the roughFoolishTech is a jewel in the rough
Default Need to check connectivity between PCs on specific port...
Is there any software, not a port scanner, but a port TESTER, where I can use to test communication between two PCs on a specific port?!?
I have a client with a software vendor who just cannot get their software to work for my client, and the client is starting to get ill with my company over the issue. The software resides on five workstations and a "server" (another workstation) all in a workgroup configuration, no domain.
The 3rd party client software seems to stall when it tries to connect to the server component, so their crappy software just sits there eating up 50% cpu appearing to do nothing but display a splash screen, and leading the software company to believe that something between the client workstation and the server is blocking it's particular UDP port. So they are throwing the ball into our court, saying there is an issue with the network we need to fix.
That may be, our client is a convention center and regularly has customers splicing into their network and messing with stuff. Last time I was physically out there a customer had plugged in their own switch in one of the closets, and had removed a patch cable from one of the main switches to plug it up, leaving several other rooms without network connectivity! Oh yeah. There is a domain and several independent workgroup setups there, several wiring closets, two server rooms, etc. It's a big place with lots of patchwork due to having different IT companies over the years. As much as that's a bad situation, they don't want to pay us to fix it. Also, we like to work remotely due to distance, so we're not going out there for some simple issue with this 3rd party software vendor when everything else on the network is working properly.
I would run a port scanner from the workstation targeted at the server to see if the port appeared open, but it doesn't -- UDP doesn't always respond well to port scanners I've discovered after reading several articles, plus who knows how the server component listening on that UDP port reacts to the scanner...
Everything else works between the two workstation and server, ping, file and printer sharing, etc. Naturally I've had the company try it's software with firewalls/anti-virus disabled. I've even formatted/reloaded Windows on both one workstation and the "server" after the software company initially blamed it on a virus.
So in short, I'm looking for a port TESTER of sorts, that I can use to test communication between two PCs on a specific port?!? Is there another way, or something more simple than I am thinking of? I'm by no means a network guru and have been assigned this issue by others who possibly are, but think their time is too valuable to mess with this issue. Any tips for me?
Thanks!
Old 08-10-2010, 02:24 AM
Elemdee's Avatar
Elemdee Elemdee is online now
Elemdee is on a distinguished road
I'm wondering if Wireshark would do what you're looking for...take a look at this...steps 4 and 5. Rather confusing looking if you've not used it before (as I haven't, lol) but it's used a lot in Networking captures, etc.
http://wiki.wireshark.org/CaptureSetup
download at www.wireshark.org
Old 08-10-2010, 02:26 PM
onetech4all's Avatar
onetech4all onetech4all is offline
onetech4all is an unknown quantity at this point
Default Re:
How about the command netstat -an to check for the open port that needs to be opened? You can use, I think, it's called fport to see what service is running on what port or the port that you need the software to run on.
Could you have software/OS compatibility issues and that's why all you get is just a splash screen?
If you need just a port scanner, that you can run against a machine on the network, use ipscan from angryziber.com.
(A+, Network+, Server+, MCSE 2003, VMware trained)
Corona CA I.T. support for businesses
"If you don't make mistakes, you don't make discoveries."
"Do what you love and you won't work a day in your life."
"Do you work to live, or do you live to work?"
Old 08-10-2010, 08:26 PM
Rodrick's Avatar
Rodrick Rodrick is offline
Rodrick is an unknown quantity at this point
Telnet?
(filler text)
Old 08-10-2010, 08:30 PM
Martyn's Avatar
Martyn Martyn is online now
Administrator
Martyn has disabled reputation
Netstat will tell you what ports are being used. It could be the port is already in use by another program, it happened to me once. You could see if you can change the port it uses a lot of programs allow this. What port number is it working on? The machine you are trying to connect to should be 'listening' on that port
Old 08-10-2010, 08:44 PM
TechguyUK TechguyUK is offline
TechguyUK is an unknown quantity at this point
Originally Posted by Rodrick View Post
Telnet?
+1 Telnet.
Setup a server on one machine, listening on whichever port you want and then use 'telnet xxx.xxx.xxx.xxx yy' where x is the IP address of the server and y is the port
TechguyUK
Computer Repair & Support in Lincoln
'Making IT...work!'
Old 08-15-2010, 03:55 PM
snifferpro snifferpro is offline
snifferpro is an unknown quantity at this point
My vote would be for Wireshark.
In basic use, you can just start a standard capture and capture all packets on
the network.
I would start Wireshark, start a capture (without filter), and have the workstation
attempt to contact the server. Let the capture run for 5 minutes then stop it. Shouldn't need
more than that.
Find the IP address of the workstation, and filter for that ip address in your capture
file.
You should see the request go out to the server and the response from the server.
If you get no response, then the problem would most likely exist on the server
and not on the network.
You can also filter on the servers ip address looking for requests from the client ip
address and the servers response. Again, if the server doesn't respond then the issue
is on the server. If there is a response from the server, then you have to look at
where that response is going.
This is where Wireshark or any packet sniffer shines.
Old 08-15-2010, 06:35 PM
Martyn's Avatar
Administrator
Yes if you understand packet/frame tracing Wireshark is definitely the way to go. Used it, and it's previous name Ethereal, many times over the years.
