Old 08-04-2010, 12:45 PM
computerdoc computerdoc is offline
computerdoc is on a distinguished road
Default Network Windows 7 to Windows 2000
The office that I'm working at just installed a new Windows 7 professional machine into a Windows 2000 network. I am trying to connect the Windows 7 machine to a printer on one of the 2000 workstations.
I changed the network compatibility in Windows 7 in order to see the rest of the network. I briefly saw the other workstations but could not see the printer.
The Windows 7 machine is running Trend Micro Internet Security and the other machines are running Norton. Would making the entire network a trusted network help?
Old 08-04-2010, 05:05 PM
Majestic Majestic is offline
Majestic is an unknown quantity at this point
Have you checked the sharing access on the printer? Perhaps adding "everyone" to the shared group would help.
Majestic
Old 08-04-2010, 05:19 PM
Martyn's Avatar
Martyn Martyn is online now
Administrator
Martyn has disabled reputation
I would temporarily take out the firewalls just as a check. Is the printer a networked printer, if so print direct to it? I've been to calls where they have a printer connected by usb and they have a network port available!
Old 08-06-2010, 01:21 AM
BeyondReality BeyondReality is offline
BeyondReality is an unknown quantity at this point
Make sure you change the name of your Domain on the Windows 7 Machine. I see this the most when people are trying to network computers together. I think it windows 7 it defaults as WorkGround and in XP and prior it is MSHOME, they have to match.
Old 08-06-2010, 03:19 AM
BDPCR's Avatar
BDPCR BDPCR is offline
BDPCR is on a distinguished road
If the machine is in a workgroup environment make sure they both have the same "workgroup" name. As recommended before disable firewalls, use proper computer names, check that proper protocols are enabled in network settings and that the host pc is sharing the printer. In a domain make sure you add the new machine to the domain, firewall disabled to test, check Domain Controller as well.
Tags
networking, windows 2000, windows 7
