Go Back   Technibble Forums > General Computers > Guides, Tips and Tricks
Old 06-18-2010, 04:12 PM
xxsilk109xx's Avatar
xxsilk109xx xxsilk109xx is offline
xxsilk109xx is an unknown quantity at this point
Thumbs up XP - Windows Update stuck at checking updates *FIX*
I ran across this and it worked for me so I thought that I would share. I had a clients computer that was XP, and virus free, it would never move past "Checking for updates..."
Here is how to fix it
If you have a Wireless Router:-
In the security tab, make sure you aren't blocking AcitveX.
Possible reasons :-
1. Internet Explorer temporary files corrupted.
2. Background Intelligent and Event Log service not started
3. SoftwareDistribution folder has become corrupted
4. You may need to re-registered some dlls files
5. You may need to add Windows Update to the Trusted Sites Zone:
6. Spyware.
7. Third party programs running in background.
8. ActiveX controls corrupted
Suggestion 1:-
Clearing Temporary Internet files, cookies and history in Internet Explorer
Tools>Internet Options>General
You'll see Delete Cookies, Delete files, Delete History
NB: "Delete all offline content", will delete all files needed to browse the websites
offline.
Reboot and try Windows Update again.
Suggestion 2:-
1: Check that the Background Intelligent Transfer Service to is set to Automatic and
verify the Status is Started.
Click Start, Choose Run, and in the Run box, type services.msc, Click OK
Locate the Background Intelligent Transfer Service service, and right-click to select it.
Select Properties, and in the Startup Type list, select Automatic. Verify the service
Status is Started. Click OK.
2. Check that the Set Event Log service is set to Automatic and verify that the Status is
Started
Click Start, Choose Run, and in the Run box, type services.msc, Click OK.
Locate the Event Log service, and right-click to select it.
Select Properties., and in the Startup type list, select Automatic. Verify the Service
status is Started. Click OK.
3. Register qmgr.dll and qmgrprxy.dll
Click Start, Choose Run and in the Run box, type regsvr32 qmgr.dll, Click OK.
Click Start, Choose Run and in the Run box, type regsvr32 qmgrprxy.dll, Click OK.
Suggestion 3:-
It is possible that the contents of the SoftwareDistribution folder have become corrupted,
so try renaming the SoftwareDistribution folder
Click Start, Choose Run.
In the Run box, type services.msc.
Click OK.
Right-click the Automatic Updates service.
Click Stop.
Stopping the service will take a moment.
Rename the "SoftwareDistribution" folder:
a. Click Start, click Run, type: %systemroot%
Click OK.
b. Right-click the SoftwareDistribution folder, and then click Rename.
c. Type SoftwareDistribution.old, and then press ENTER to rename this folder.
Click Start. Choose Run.
Click OK.
Click Start.
Starting the service will take a moment.
Please note that your update history is contained in the "datastore" folder and when you
rename the Software Distribution folder, the history is lost but it's not important. You
can if need be, copy the contents back from the renamed softwareDistribution.old folder.
Losing the history of Windows Updates is not important.
Suggestion 4:-
Certain files may have become unregistered, and you will need to register them again:-
Click Start, Choose Run and in the Run box, type regsvr32 wuaueng1.dll, Click OK.
Do the same for the other files:-
wucltui.dll
wuaueng.dll
wuapi.dll
jscript.dll
MSXML.DLL
MSXML2.DLL
MSXML3.DLL
Suggestion 5:-
Add Windows Update to the Trusted Sites Zone:
Please note that Security settings in Internet Explorer must be set to Medium or lower for
ActiveX files to correctly pass to your computer.
Only the Web sites listed in Internet Explorer's Trusted Sites Zone will be affected by
the lowering of Security settings. Your current security settings for all other Web sites
will remain as they are currently configured.
Open Internet Explorer, click Tools, and then click Internet Options, Click Security.
Click Trusted Sites Zone. Click Sites.
Clear the Require server verification (https for all sites in this zone check box.
Use the Add button next to the Add this Web site to the zone box to add the following
sites:
http://*.update.microsoft.com
https://*.update.microsoft.com
http://download.windowsupdate.com
Suggestion 6:-
The below links assist you in checking your system for parasites:-
http://aumha.org/a/noads.htm
http://inetexplorer.mvps.org/tshoot.html
Please note that some malware may kill the internet connection when it is removed, the
program on the link below will enable you to regain the internet connection.
http://www.cexx.org/lspfix.htm
Spyware Programs links:-
http://www.microsoft.com/athome/secu...e/default.mspx (Windows Defender)
www.lavasoftusa.com Ad-Aware
www.security.kolla.de Spybot
Malware Removal
http://www.elephantboycomputers.com/...moving_Malware
THE PARASITE FIGHT - Finding, Removing & Protecting Yourself From Scumware
http://aumha.org/a/parasite.htm
Richard Harper's Guide to Cleaning Pests
http://rgharper.mvps.org/cleanit.htm
Suggestion 7:-
Make sure you haven't got anything blocking Windows Update like Nortons, Zonealarm etc
Also make sure you don't have a Web Accelerator working in the background such as
NetZerio, HiSpeed, Speedband etc.
Suggestion 8:
If you need to reinstall the ActiveX controls (because they may have become corrupt):-
Follow this article -
The Windows Update Web site and the Microsoft Update Web site do not scan for updates when
you repair a failed installation of Windows XP Service Pack 2 or of Windows XP Service
Pack 1
http://support.microsoft.com/kb/916259
or use the command: WindowsUpdateAgent30-x86.exe /wuforce
Keep Calm and Chive On!
Old 06-18-2010, 08:42 PM
JW The Computer Guy JW The Computer Guy is offline
JW The Computer Guy is an unknown quantity at this point
Send a message via MSN to JW The Computer Guy
Or you could just run Dial-a-fix.
Old 06-18-2010, 09:40 PM
iisjman07's Avatar
lol.........................
Old 06-19-2010, 06:40 AM
Cambridge PC Support's Avatar
Cambridge PC Support Cambridge PC Support is offline
Cambridge PC Support has a spectacular aura aboutCambridge PC Support has a spectacular aura about
now where's the fun in that?
Old 06-22-2010, 06:03 PM
I tried to run Dial-A-Fix and for some reason it didnt work so I had to take this route!
Old 06-22-2010, 09:25 PM
Oh
filler text......
Old 06-24-2010, 12:36 AM
Well I just didn't know the number to DIAL I guess
