Go Back   Technibble Forums > Technical Discussions > Hardware
Old 05-28-2010, 07:55 PM
OhioTech's Avatar
OhioTech OhioTech is offline
OhioTech is an unknown quantity at this point
Angry ACER ASPIRE 5810tz - Bios password help
I have googled for days. I am in a real jam. Operating system (Windows 7) is toast. Tried to boot to a cd, but bios is password protected. Only can get the machine to boot to a cd if I remove the hard drive. Can't use F12 option since it is disabled. Would like to reinstall the OS but since no HD, windows boot disk doesn't see disk.
Owner bought it used. (saw documentation). Doesn't know password. Tried all the backdoor passwords - no love. Machine doesn't throw an error code to try to crack the password. Unplugged the cmos battery overnight- no good. Password must be saved on a chip. Tried Hiren's boot cd- bios crack errors out on the cd-rom. Even took the keyboard off (6 tabs) to see if there was a jumper of some sort.
This is looking bad. The system is only 7 or 8 months old. Any ideas?
Stowers Computer Services
East Liverpool, OH 43920
http://www.stowerscomputerservices.com
Old 05-28-2010, 08:29 PM
dannyd dannyd is offline
dannyd is an unknown quantity at this point
If you use a program for removing the password then you need to put the hard
drive into another machine or slave the drive. but easiest solution is to put a new hard drive in.
Old 05-28-2010, 08:32 PM
iptech iptech is offline
Banned
iptech is on the way
Take the hard drive out and copy a boot environment such as Boot PE to the hard drive. As long as you get one with CD drivers that work for that machine (Acer can be buggers) you'll be cooking with gas.
Old 05-28-2010, 09:47 PM
OhioTech's Avatar
I think add that might do to the trick! Or I could load it then flash the bios?
Old 05-29-2010, 12:45 AM
Banned
You won't be able to flash the BIOS unless you have the password. The BIOS is locked and effectively fubar'd, you need to work with what you have.
Old 05-29-2010, 02:50 AM
Checkmate's Avatar
Checkmate Checkmate is offline
Checkmate is an unknown quantity at this point
Send a message via AIM to Checkmate
Just had an issue with Aspire 5515, and there is a h/w switch under the ram. If not, have you tried BIOS_PW.exe? That may work
Checkmate Computer Solutions
The Games end at Checkmate!
Old 08-03-2010, 10:21 AM
rahimhd rahimhd is offline
Banned
rahimhd is an unknown quantity at this point
Send a message via Yahoo to rahimhd
Maybe i can help. Visit my site: http://www.acersnoop.co.cc. Read the readme page first
Old 08-03-2010, 04:05 PM
iisjman07's Avatar
You should check the whole motherboard for jumpers
  #9
Old 08-03-2010, 06:15 PM
curious_mindz curious_mindz is offline
curious_mindz is an unknown quantity at this point
http://www.tech-faq.com/reset-bios-password.html
Read this article this will help i think,
Go with the Resetting the BIOS Password using Hardware option since u have only this option left.
he suggests if the resetting the battery and the jumper method fails then u will have to take the RTC chip of the board and put it back will take lota time but yea since its ur only option right.
  #10
Old 08-03-2010, 08:54 PM
OnSiteSolutions OnSiteSolutions is offline
OnSiteSolutions is an unknown quantity at this point
I had this same problem recently. You will find that a bios AND sata password has been set, probably by a virus.
The ONLY way to get past this is using a service, such as Rahim's in this thread. I have used him for this same problem with an acer, and he will provide you with the password.
