Old 01-09-2008, 11:29 PM
Kyrus Kyrus is offline
Kyrus is an unknown quantity at this point
Default Laptop Screen Very Dim
Hi all,
I have a Toshiba Satellite Laptop, the lcd screen is very dim, you can just about see the logon screen, if i plug an external monitor that works fine.
I did replace the inverter, but that did not help.
I don't have that much experience with laptops.
Any ideas??
Old 01-10-2008, 12:12 AM
gunslinger's Avatar
gunslinger gunslinger is online now
gunslinger will become famous soon enough
Send a message via Skype™ to gunslinger
Had this problem twice recently. The first time it was the cable that connects the display to the MOBO, caused I think by moving the LCD out of range. Simply plugging it back in solved the problem. The second time it was the LCD going out. Pop of the front strap infront of the LCD behind the keyboard per the instructions and make sure the cable in plugged in securly. Also, and I'm sure you have already done this, check to make sure the brightness is turned up first.
Old 01-10-2008, 03:24 AM
BeyondReality BeyondReality is offline
BeyondReality is an unknown quantity at this point
The backlight on your LCD is bad. You need to replace the LCD. Can get expenive. It is definetly the backlight it has nothing to do with the plugs because the image wouldnt come up at all or it would come up distorted. definetly backlight, expecially if it works on external monitor...
Old 01-10-2008, 10:03 PM
Bryce W's Avatar
Bryce W Bryce W is offline
Administrator
Bryce W will become famous soon enough
I second that its the LCD backlight that has died.
Owner and Founder of Technibble - If you have a problem with any user, they are flaming/being elitist/making snide comments etc.. Press the report button which is on the top right of every post. This will highlight the post in an admin area for staff to see and deal with.
For adminly tasks such as username changes, moving threads etc.. please contact Martyn
Check out Technibbles twitter: http://www.twitter.com/technibble
Old 01-10-2008, 11:50 PM
Simmy's Avatar
Simmy Simmy is online now
Super Moderator
Simmy is on a distinguished road
Send a message via MSN to Simmy
Thirded. I find ebay is the best place for sourcing replacement LCDs at decent prices.
Old 01-11-2008, 03:21 AM
gunslinger's Avatar
depending on the age of the laptop you might be able to just get the backlight.
Old 01-11-2008, 05:49 PM
Thanks for the replys all, the laptop was purchased in 05, i'll have to start checking ebay.
Old 01-11-2008, 07:07 PM
nonchalant's Avatar
nonchalant nonchalant is offline
nonchalant is on a distinguished road
Yea I saw this problem on a customers new Toshiba recently. When the LCD was 'moved' it would flicker from bright to dull. Warranty job.
  #9
Old 01-25-2008, 08:55 PM
ftbendpc's Avatar
ftbendpc ftbendpc is offline
ftbendpc is an unknown quantity at this point
Before you buy an lcd check into the inverter board. This is the device that powers the backlights. The cost of an inverter board is around 70.00 you can also have the backlights replaced by someone but I would not recommend doing it yourself it can be very difficult.
