Go Back   Technibble Forums > Operating Systems > Linux
Old 05-26-2010, 07:21 PM
Morrison5891's Avatar
Morrison5891 Morrison5891 is offline
Morrison5891 is on a distinguished road
Send a message via MSN to Morrison5891 Send a message via Yahoo to Morrison5891
Default Blank lines in the Grub menu
Is it possible to have blank lines in grub4dos? Like the example below ....
Linux
Windows
Ultimate BootCD
AVG Rescue CD
Hiren's Boot CD
Memtest
Active Boot Disk
AOSS
Old 05-26-2010, 08:47 PM
dbdawn dbdawn is offline
dbdawn is on a distinguished road
I don't know much but about grub but could you put a dummy entry in your menu?
In my syslinux menu I have the following and that gives me a space in between my entries.
Code:
LABEL blank
MENU label
Old 05-26-2010, 09:01 PM
I'm not sure if that will work or not... i'm gonna try it right now.
I've also tried
title *
and that didnt work for me!
Old 05-27-2010, 02:05 AM
well... with about 3 hours of more research i've come up with this... in the menu config file you need to add this:
#this is for a space
title
kernal
initrd
So the menu config should look like this...
title Hiren's Boot CD
find --set-root /Hirens.iso
map /Hirens.iso (hd32)
map --hook
root (hd32)
chainloader (hd32)
title
kernal
initrd
title AVG Rescue CD
find --set-root /avgrescuecd.iso
map /avgrescuecd.iso (hd32)
map --hook
root (hd32)
chainloader (hd32)
Thanks for the reply... and hope this helps other people using a multiboot usb stick
Old 10-02-2010, 03:57 PM
wimwauters's Avatar
wimwauters wimwauters is offline
wimwauters is on a distinguished road
So can grub boot ISO files, or are you guys creating a bunch of partitions to dump your ISOs into?
Old 10-03-2010, 03:26 PM
coreyspeed coreyspeed is offline
coreyspeed is an unknown quantity at this point
yep grup can boot iso files, take a look at pendrivelinux.com
Old 10-04-2010, 09:28 AM
wimwauters's Avatar
Excellent, I'm glad I did, because PenDriveLinux also supports utility ISO's like UltimateBootCD and AVG/Kasperski/Avira !
From their website, I got the impression that PendriveLinux only supported operating system ISO's.
PendriveLinux is VERY easy to use and convenient.
I'll also be using SARDU (Shardana Antivirus Rescue Disk Utility): this one supports even more ISO's, but requires a little bit more work: i.e. you have to download the ISO's yourself... after SARDU launches your webbrowser and puts it on the download page
I'm so glad I didn't get round to this since 2006, things are a lot easier now
Old 10-04-2010, 09:52 AM
yep use it very day on my USB, have load of tools on it, so are more work if you want to organise the drive but if you keep them all in the root it should be fine
  #9
Old 10-04-2010, 11:46 PM
jae jae is offline
jae is an unknown quantity at this point
I don't think you can enter blank lines into GRUB the cfg/lst I remember GRUB having trouble with blank titles years ago. The closet you will get is making an entry linked to dummy files, and for title make it an * or -. Dont think its worth that much trouble though.
  #10
Old 10-06-2010, 05:57 AM
You can enter blank lines... read my last post
Comp U More - On-Site Computer Repair & Home Theater Service.
computer repair pocatello
computer repair lava hot springs
home theater service pocatello
Error: Keyboard not attached. Press F1 to continue.
