Go Back   Technibble Forums > Technical Discussions > Hardware
Old 05-07-2010, 09:41 PM
ell ell is offline
ell will become famous soon enough
Default Speedfan core temp 65C
Hi, I have a Dell 1501 that shuts down suddenly. (Vista home prem AMD 64 X2 dual core 2gb memory) This has come back to me because apparently I missed the cause last time, she had malware and too many startups and I ran hardware scans, it came through fine. So this time I installed speedfan and started 2 ie windows, outlook, photoshop, core temp peaked at 74C. Seems to run between 50-65C with just ie running. (I have just 50 processes running in task manager runs very fast and well, I also set Vista to best performance) I did blow air through the vents, its appears very clean. I left it running, came back 1/2 hr later, shut down. No logs either. Disabled hard drive shut down in power mgnt too. Customer clams the fans seems to run hard before it shuts down. Bad memory??? too high temps?
Old 05-08-2010, 11:21 PM
JRDtechnet JRDtechnet is offline
JRDtechnet is on a distinguished road
the dust usually cakes up on the fins near the fan and no amount of compress air will clear it out. You have to remove the heatsink and fan assembly and then take out the fan itself and look a the fins you'll probably just see a grey wall of dust and hair....just peal that off and then give a shot of air.
Computer Repair NJ
