Go Back   Technibble Forums > Site Stuff > Repair Tool of the Week Suggestions
  #11
Old 05-06-2010, 02:45 PM
davidecosta's Avatar
davidecosta davidecosta is offline
davidecosta is an unknown quantity at this point
Send a message via MSN to davidecosta
Originally Posted by kagman View Post
How do I tell it which one is the 32bit and 64bit versions?
Puth both ISOs in the folder ISO, SARDU know if is a 32 or 64 bit.
SARDU
Mens sana in corpore SARDO
  #12
Old 05-06-2010, 03:04 PM
kagman's Avatar
kagman kagman is offline
kagman is an unknown quantity at this point
Send a message via AIM to kagman Send a message via Yahoo to kagman
Thank you. That worked and its now on the list..
--Jose--
"Everyone Needs their own I.T. guy :)"
From Queens, New York
  #13
Old 05-14-2010, 07:36 PM
Avgsmoe's Avatar
Avgsmoe Avgsmoe is offline
Avgsmoe is on a distinguished road
I love the tool, thanks a lot!
One question, Is there a way I can get MSDaRT discs working?
Id also love to see KonBoot, but not that big of deal
Edit: ERD Commander works just renamed as xplive.iso (since im not using that anyway,) but vista, and 7 DaRT would be nice. I did try putting those ISO's in place of vista and 7 recovery, but it did not load properly.
  #14
Old 05-14-2010, 10:48 PM
kagman's Avatar
I had a similar issue with the DaRT iso images. The way around it took me a while but this was my solution. First of all for my needs I am unable to get everything I need onto 1 DVD. Granted this program made it so that i can carry less cd's with me, but just one is not a good idea.
The issue at hand is that for some reason Sardu allows you to use both Windows 7 32bit and 64bit but not Vista. So in effect that is the solution. This will require you to carry 2 discs instead of 4, which is still not bad. Since there are 2 versions of Vista DaRT, the 32bit and 64bit, just remain them to what the windows 7 files are for Sardu.
Example: in the Sardu ISO folder put your Vista DaRT ISO images in there. Then rename them to Windows_7_32-bit_Repair_Disc.iso and Windows_7_64-bit_Repair_Disc.iso. Now run Sardu. If you click on the PE tab you will see that for the "win recovery disk" there is already a check mark on the "windows 7 recovery disk". Click on make iso and you are done. Label your new cd "vista DaRT's or something else so that you know this is for a windows vista computer. When you boot from the cd the menu will still say its windows 7 32 and 64bit versions but once you boot into those images you will see your vista DaRT load
Its not a prefect solution but it works.
--Jose--
  #15
Old 05-14-2010, 11:33 PM
Avgsmoe's Avatar
What I am doing now is just ripping the data from the disc of the 64 bit 7 and vista. Coping the data to a temp location, renaming the folders. Then ripping the 32s. Copy the 64 bits back over with the new folder names, and editing the sardu/menu/pe.cfg to reflect the correct directories for all DaRT.
I also got my copy of spinrite added in.
  #16
Old 05-14-2010, 11:44 PM
kagman's Avatar
How did you get spinrite in there?????? tell me.... PLEASE!!!!!!!!!
--Jose--
  #17
Old 05-15-2010, 12:06 AM
Avgsmoe's Avatar
I put a copy of spinrite.img in the root. Then added it to utility.cfg
Code:
label Boot from Spinrite
menu label Boot from ^SpinRite
      KERNEL memdisk
MENU INDENT 1
    append initrd=/SpinRite.img
Edit; I also got konboot working now
  #18
Old 05-15-2010, 01:54 AM
kagman's Avatar
OMG!!!! I will need to try this.. THANK YOU THANK YOU THANK YOU THANK YOU
--Jose--
  #19
Old 05-15-2010, 02:49 PM
Dart and Spinrise aren't freeware
SARDU is a collection of freeware that I download from internet and i and I test personally in multiboot.
SARDU
  #20
Old 05-16-2010, 05:57 PM
madmark madmark is offline
madmark is an unknown quantity at this point
Slightly off topic but i found some write protected usb drives on newegg the other day .. they are made by pqi and have a physical switch that u can flip to lock the drive. I got the 8gb drive and it was about $20 and it works great.
