What are some of the most common things that viruses attack? What functionality do you check on when making sure that a machine is fixed?
- broken file associations - start button, start menu, task bar gone - add/remove programs will not populate |
-Home page
-Internet browser settings (mostly IE) -Task manager -Network settings (IPv4, UDP, file sharing settings) -Network shares -Antivirus programs -Media player -Messenger programs -OS startup -Regerstering IE .dll files -Various missing Dll or system files -Various services not starting when they should -Remote access disabled (get alot of this at work, makes accessing a computer on the other side of the campus annoying) -DNS cache poisoning or having your DNS server completely changed (could fall under Network settings I suppose but meh). edited here -Flash player disabled/not working -Java disabled/not working All I can think of off the top of my head. Last edited by Squeak; 04-27-2010 at 02:11 AM. Reason: Edit thought of more just after hitting post |
I had one today redirect internet traffic with a proxy setting in IE that shot it back through local host. made internet not work once virus was removed. Easy fix though.
CyberCPU Computer Repair |
Internet settings, connections, disable proxy and re-enable automatic settings. All it did was set a proxy that directed traffic to 127.0.0.1:5555
Hosts file
Regedit IE Trusted Zone Firewall settings/exceptions |
Can't see wallpaper restrictions anywhere...
put that in your pipe and grep it |
Perhaps registry changes as described here... http://www.askvg.com/how-to-prevent-...er-in-windows/ |
#9
This is another reason why I like to infect VM's so I can play with strange post infection problems and get the computer running correctly again.
Sometimes I will infect a VM fix it infect it with something else. After doing this a few ties other problems will show up that would not normally. I don't always start with a clean snapshot.
#10
Ok, so far we have:
-Home page -Internet browser settings (mostly IE) e.g. proxy, etc. etc. Check everything. -Task manager -Network settings (IPv4, UDP, file sharing settings) -Network shares -Antivirus programs -Media player -Messenger programs -OS startup -Regerstering IE .dll files (check with Winpatrol, and for BHO, etc. other misc. stuff) -Various missing Dll or system files -Various services not starting when they should -Remote access disabled (get alot of this at work, makes accessing a computer on the other side of the campus annoying) -DNS cache poisoning or having your DNS server completely changed (could fall under Network settings I suppose but meh). (Reset LMHOSTS)? -Flash player disabled/not working -Java disabled/not working - Hosts file - Regedit - IE Trusted Zone - Firewall settings/exceptions Can anybody add any others?
2 Corinthians 5:21 "For God made Christ, who never sinned, to be the offering for our sin (by dying in our place), so that we could be made right with God through Christ." |
| Thread Tools | |
| Display Modes | |
