Go Back   Technibble Forums > Technical Discussions > Software Applications
Old 04-18-2010, 01:17 AM
kozman kozman is offline
kozman is an unknown quantity at this point
Default DriveImage XML Restore
I used DriveImage XML to back a hard drive from a HP zd7140 laptop. Split the files up to fit on cds. Saved them all on another drive. Twenty some files along with the .dat file and .xml it creates. I repaired the laptop. Had to change out the mother board.
Problem is when I try to restore the image back to the same hard drive it gets to 54% then stops with an error.
Error: Notify Exception
Read Error: The operation completed successfully.
Info: Patitioin Copy Error
Address 004E153D
Stack Dump
Only button to choose is "Cancel".
Tried three times. Tried formatting the hard drive NTSf before restore. Tried formatting "fat32" before restore. Windows XP Home is on the image.
Anyone have any info that can help me out. I have search and foundpeople having the same issue but no answer.
Peace,
kozman
Last edited by kozman; 04-18-2010 at 01:20 AM. Reason: Two signatures of the same.
Old 04-18-2010, 08:28 AM
iisjman07's Avatar
First thing I'd check is whether or not the drive is functioning correctly. Scan for bad sectors, then check in Drive Image XML and see if there is anything you can use to check the backup, Acronis True Image has something called 'Validation'...
