Go Back   Technibble Forums > Technical Discussions > Hardware
Old 04-08-2010, 07:01 PM
stevenamills stevenamills is offline
stevenamills is on a distinguished road
Default Laptop battery won't charge
I have a Toshiba Satelite A305-s6872 on the bench that refuses to recharge the battery. I have 2 batteries for it - One showing 0% and the other 32%. When plugged in and operating both say the battery is charging, but nothing happens. As long as I'm plugged in, everything runs great.
I upgraded the BIOS on the off chance that would help, but no luck.
I don't know the workings of a laptop as well as I should. Is there a "charging circuit" that may be bad or could the DC Jack supply power for everything but the battery?
I did try 2 different charging units also - same result.
Any place I should look or something I should try. I see a couple of people in my Google search with similar issues.
Thanks for any help.
Steve
Fox Valley Computer Services
Trying desperately to make a living in a failing industry in a failing economy.
Old 04-08-2010, 08:41 PM
Cuban_Tech's Avatar
Cuban_Tech Cuban_Tech is offline
Cuban_Tech is an unknown quantity at this point
Send a message via ICQ to Cuban_Tech
Lightbulb
It may be that you need new batteries. Now on Lenovo laptops there's something called a "Battery Gauge Reset" that will work 75% to 80% of the time. It is part of the Power Manage app. from Lenovo. You may want to use Google to see if Toshiba offers something similar. Good luck!
This isn't about fixing computers. It's about fixing users.
http://www.fredyitsolutions.com
Open source for life!
Old 04-08-2010, 09:16 PM
anonymous Mac Tech's Avatar
anonymous Mac Tech anonymous Mac Tech is offline
anonymous Mac Tech has a spectacular aura aboutanonymous Mac Tech has a spectacular aura about
Does it run on battery alone with the battery that has some charge left?
[FONT=Arial]ACMT[/FONT]
People fear what they don't understand and hate what they can't conquer. Andrew Smith
Old 04-08-2010, 10:26 PM
It does. Seemingly very normal.
Steve
Old 04-08-2010, 11:13 PM
Skyhooker's Avatar
Skyhooker Skyhooker is offline
Skyhooker is on a distinguished road
Thumbs down
It sure might be a bad power jack. The nice thing about that one is it isn't soldered to the board (I never understood that idiotic design, shared by so many manufacturers), rather it has a wire harness from the jack to the board. Here's one on ebay, for example, for $17 + shipping:
A305-s6872 Power harness
Good luck!
Sorry, not sure why the "thumbs down" appeared in my reply - nothing personal!!
Old 04-09-2010, 03:29 AM
That's what I like about Macs. They've done away with soldered jacks since way back with ending the titanium powerbooks.
EDIT: Sorry to hijack. A good way to test if its a separate circuit with a charging issue is if the machine will run with a known good battery, its likely a jack or mobo. IF it doesn't run on battery its likely its not a jack and there is a separate connection to the board for battery power.
Old 04-19-2010, 07:29 PM
Well, it looks like this one beat me. I'm out of ideas.
I tried a new battery and it runs fine on battery power, but no charge.
The icon in the lower light always says "plugged in and charging", but the % never moves.
I never could locate a "power manager" on the Toshiba site.
I replaced the DC power jack.
I hate these things to beat me.......
I removed the battery and charger from the device manager and it found them and reinstalled.
Steve
Old 04-19-2010, 07:50 PM
usacvlr's Avatar
usacvlr usacvlr is offline
usacvlr is on the way
It's the MAXIM chip on the board. It's toast or has come loose.
You Break It. We Fix It!
http://www.usalaptoprepair.com
  #9
Old 04-19-2010, 08:02 PM
NYJimbo's Avatar
NYJimbo NYJimbo is offline
NYJimbo has a spectacular aura aboutNYJimbo has a spectacular aura about
+1. Probably baked. Easy to spot too.
  #10
Old 04-19-2010, 10:24 PM
Thanks for taking the time.
Much appreciated.
Steve
