Old 04-01-2010, 05:45 PM
transisto transisto is offline
transisto is an unknown quantity at this point
Default Admin right and security
How easy is it to do so after the fact ? removing "Administrator" admin right ?
I thought I could rename the "Administrator" name a be a bit safer , but don't see how in Win7
And help would be apreciated.
had a look at arstechnica.com/microsoft/news/2010/03/half-of-windows-flaws-mitigated-by-removing-admin-rights.ars?comments=1#comments-bar
Old 04-01-2010, 06:50 PM
jaydude23's Avatar
jaydude23 jaydude23 is offline
jaydude23 is an unknown quantity at this point
Renaming an account in windows is not going to change the permissions of the account. It simply changes the display name of the account.
To remove admin rights for an account, you must change the account type. This is done under control panel, user accounts.
Keep in mind that you must have at least one account with admin rights on a system.
You can create a standard user account and use that for daily use. Use the admin account when you need to make system changes only.
Old 04-02-2010, 05:48 AM
Well I think it's more secure because someone from outside does not know the name of the admin account nor the password.
It seams the first administrator account cannot be withdrawn his admin right, I guess I need to boot in the new admin account.
Old 04-02-2010, 06:21 AM
sjlplat's Avatar
sjlplat sjlplat is offline
sjlplat is an unknown quantity at this point
Why not create a new Administrator account and disable the default one?
Code:
net user administrator /active:no
Old 04-02-2010, 07:30 AM
iisjman07's Avatar
http://www.technibble.com/forums/showthread.php?t=11116 enables you to enable/disable the default admin account on Vista/Win7 systems
Old 04-02-2010, 09:00 AM
pcSAVANTS pcSAVANTS is offline
pcSAVANTS is an unknown quantity at this point
rename admin in win7
start>type gpedit.msc
computer configuration>windows settings>security settings>security options
at the top of the list you can rename the administrator
or you can install Windows 7 God Mode and it should be in there.
Phoenix Computer Repair AZ
