Go Back   Technibble Forums > Technical Discussions > Hardware
Old 03-17-2010, 09:36 AM
pg07143's Avatar
pg07143 pg07143 is offline
pg07143 is an unknown quantity at this point
Default Is there only one good stick of memory on the planet?
I have a machine that was blue screening consistently on boot. It is a Dell Dimension 4700 that has 2 X 256MB PC2-3200 RAM installed. I removed one of the sticks and the machine started working fine. I moved the working stick to each of the 3 memory slots and everything stayed stable. I advised the customer to upgrade memory and I bought 2 X 1GB PC2-5300 RAM (PNY). When I installed the new RAM, the machine started blue screening immediately. I ran individual memory tests on the new RAM and it fails miserably. I am doubtful that I got 2 bad sticks of memory, but ordered 2 more just to be sure.
One thing of interest that I noticed is that one of the capacitors near the RAM slots is slightly bulged at the top. I would totally expect a bad cap to cause this type of behavior, but the fact that the computer runs fine with one of old 256 sticks of memory makes my head hurt . Anybody out there have similar experiences?
Old 03-17-2010, 10:45 AM
MobileTechie's Avatar
MobileTechie MobileTechie is online now
MobileTechie will become famous soon enough
I don't think I've ever bought a bad stick of RAM but I'm sure it will happen.
The chances of all 4 of those sticks being bad seems a bit low. I think you should test the on your bench machine to see if you get the same results.
Old 03-17-2010, 11:45 AM
pg07143's Avatar
I know, it should be that easy. Believe it or not I don't currently have any other desktop machines that take DDR2 . I need to get another bench machine soon.
Old 03-17-2010, 01:51 PM
ATTech ATTech is offline
ATTech is on a distinguished road
Happened to me. Client had two sticks of RAM, determined that one was bad, went to Fry's and bought another one, got back and stuck it in, wouldn't boot. Determined that the new stick was bad, went and exchanged it. The new new stick worked.
Old 03-17-2010, 02:25 PM
anonymous Mac Tech's Avatar
anonymous Mac Tech anonymous Mac Tech is offline
anonymous Mac Tech has a spectacular aura aboutanonymous Mac Tech has a spectacular aura about
Well you have 2 different speeds of RAM so no wonder. I'd stick with testing with the exact spec RAM. Also a bulging cap is a blown cap waiting to happen. As far as the caps are concerned I've seen machines run fine with several blown caps and other machines crap right out with one slightly bulged cap. But most of the time if the cap is domed its going to blow eventually. Let them know about the cap and let them make the call if they want to pursue it further.
[FONT=Arial]ACMT[/FONT]
People fear what they don't understand and hate what they can't conquer. Andrew Smith
Old 03-17-2010, 03:03 PM
NYJimbo's Avatar
NYJimbo NYJimbo is offline
NYJimbo has a spectacular aura aboutNYJimbo has a spectacular aura about
I would take the new "bad ram" and stick it in a known good computer and runs memtest86+ against it.
If its clean then you got other problems. If it fails then you got bad ram.
Thats how you check when you got this kind of situation. Dont assume the new ram is bad because its failing in the machine you bought it for.
If you dont have a machine to test it then you are stuck, not a good place to be when clients are depending on your expertise.
Building a machine that can take DDR2 should cost you almost nothing.
Old 03-17-2010, 03:57 PM
onetech4all's Avatar
onetech4all onetech4all is offline
onetech4all is an unknown quantity at this point
Default Re;
Yup, same here.
I got a Dell Inspiron 1150 from a friend for free with only 512 MB. Went to Fry's to buy 2 Gigs. Got home, installed the Ram, laptop would not boot up. It came down to 1 GB memory stick that was bad. (I am sure it wasn't static that killed it). Got it replaced, everything is running just great. My wife loves her present.
When I was working for this computer store in O.C., this guy brings in his desktop with a hard drive problem (HDD crashed). He bought 2 Sata hard drives, brand new, from Frys. My colleague has problem with one of the hard drives to make it take Windows XP. He calls me for ideas, after playing around with the BIOS, cables, etc. Found out BIOS was not reading the HDD, which lead to the conclusion that it was a bad hard drive. We didn't bother testing more; we just used the 2nd Sata HDD and fixed the desktop. We got the other drive replaced.
In a nutshell, you will get brand new hardware that is bad from out of the box. It's not out of the ordinary.
(A+, Network+, Server+, MCSE 2003, VMware trained)
Corona CA I.T. support for businesses
"If you don't make mistakes, you don't make discoveries."
"Do what you love and you won't work a day in your life."
"Do you work to live, or do you live to work?"
Old 03-17-2010, 04:25 PM
Elemdee's Avatar
Elemdee Elemdee is online now
Elemdee is on a distinguished road
Hopefully this next set of RAM you ordered is PC2-3200 to match the specs of the machine.
  #9
Old 03-17-2010, 06:22 PM
The machine can take 5300 memory.
  #10
Old 03-17-2010, 06:25 PM
Blues's Avatar
Blues Blues is offline
Blues is on a distinguished road
Also test the new RAM in a good machine before installing it to know if the machine is killing it.
