Old 03-08-2010, 02:19 AM
rtorres15's Avatar
rtorres15 rtorres15 is offline
rtorres15 is an unknown quantity at this point
Send a message via AIM to rtorres15
Talking Migrating Files and Settings
What's the best way to Migrate Files and Settings for a customer running XP, Vista and 7 ?
www.systemsunitedllc.com
Los Angeles,CA
Old 03-08-2010, 02:24 AM
Xander's Avatar
Xander Xander is online now
Xander has a spectacular aura aboutXander has a spectacular aura about
I've had XP's migrator fail so many times I've stopped using it. I'll usually run it and, while it's running, start backing stuff up manually.
I've had great success with 7's Easy Transfer. Can't remember if I've used it in Vista, though.
Xander St Catharines Computer Repairs
New here? Watch this and read this.
Remember, it's not our problem, it's yours so ask your questions well.
Old 03-08-2010, 08:47 AM
diggauk diggauk is offline
diggauk is an unknown quantity at this point
Are you migrating because of a reinstall of the original OS, or because of an OS upgrade?
If it's because of a reinstall, I normally image the drive on to an external, then wipe and reinstall the OS. Then copy across all the needed files.
If it's an OS upgrade, I would use the Windows Easy Transfer for 7, as it's been a great tool and takes away all of the guess work.
Old 03-08-2010, 01:24 PM
Fixedathome.com Fixedathome.com is online now
Fixedathome.com is an unknown quantity at this point
I've also had a lot of success with the Easy Transfer Wizard. There is a download available to use it on XP as well.
Old 03-09-2010, 02:41 AM
RegEdit RegEdit is offline
RegEdit is on a distinguished road
As far as XP goes, you might try some or all of these for redundancy....
- Todo drive image backup for safety
- Back up with XP Files & Settings Transfer Wizard (Use same XP CD for export and import)
- Back up license keys w/ Belarc Advisor, License Crawler
- Back up passwords with Nirsoft
- Use Keyfinder 2.0 to recover Window product ID
- http://www.technibble.com/tools/windowsid/ to ID Windows version OEM, Retail, Corporate, Volume License
- Back up Certificates with MMC.exe
- Backup email with MozBackup
- DriverMax backup
Old 03-09-2010, 05:33 AM
trapped's Avatar
trapped trapped is offline
trapped is an unknown quantity at this point
Send a message via MSN to trapped Send a message via Yahoo to trapped
I've had a string of bad luck with Easy Transfer over the network. I have had no problems transferring using an external HD it just takes a little longer.
Get a Geek. Get it Done.
Computer, Networking, and Home Theater installation, service and repair in the Greater Sacramento, CA Region.
http://www.thecomputergeeks.com
Old 03-09-2010, 01:50 PM
stevenamills stevenamills is offline
stevenamills is on a distinguished road
I see Zinstall advertising here - has anybody tried it. A hhundred bucks a migration seems pretty steep.
I haven't found a migration tool I like since Gates bought Aloha Bob and buried in the bowels of Redmond - never to be seen again.
Steve
Fox Valley Computer Services
Trying desperately to make a living in a failing industry in a failing economy.
Tags
backup, migrate, transfer, windows
