Old 03-06-2010, 04:30 PM
WHEELS WHEELS is offline
WHEELS is an unknown quantity at this point
Question Bad motherboard?
I have a clients computer which will not turn on at all. Here are the things that I have tried. Any other suggestions are appreciated.
Tested their power supply with tester, all is good, but still won't power on
Tested with known good PSU, still will not turn on
Unplugged each cable one by one, still won't turn on
Removed each piece of hardware one by one, still nothing
Removed cmos battery, still nothing
Old 03-06-2010, 04:40 PM
Cambridge PC Support's Avatar
Cambridge PC Support Cambridge PC Support is online now
Cambridge PC Support will become famous soon enough
Have you tried removing all of the cables from the mobo that connect from the front panel and then shorting out the PWR SW one?
Old 03-06-2010, 04:45 PM
NYJimbo's Avatar
NYJimbo NYJimbo is offline
NYJimbo is a jewel in the roughNYJimbo is a jewel in the roughNYJimbo is a jewel in the rough
You could tell us the make and model of this computer.
Old 03-06-2010, 04:57 PM
The computer is a Compaq Presario SR2039X.
@ Cambridge PC Support, I shorted out the PWR SW and still nothing so the switch is not bad
Old 03-06-2010, 05:44 PM
Pesti's Avatar
Pesti Pesti is offline
Pesti is an unknown quantity at this point
Check the mem chips, try a known good one, same with the CPU, IF no luck try pulling the board from the case, and trying it on a test station, For some reason I've had better luck checking a pc this way..
Old 03-06-2010, 06:20 PM
NYJimbo's Avatar
Ok, wont turn on at all. Does that mean you get ANY kind of movement on the system?. Fans, blinking lights of any kind?. DVD/CD drive movement, HD drive seek powerup, floppy recalibration (seek/settle) ?
Do you see any life on any part of the machine ?
If so provide specific details of what you DO see.
Can you put in a generic PSU and bypass any front panel switches ?.
If there is strapping on the motherboard that you can defeat you might want to order one of these for the future. It will help to determine if switches are bad :
http://www.highspeedpc.com/Merchant2...ionAccessories
I have several of them and have helped in situations similiar to this one.
Old 03-06-2010, 07:06 PM
ooooh they're nice
