Thread Tools | Display Modes |
Well I got a couple laptops in that were affected by the Windows update issue. Which, by the way, seems to only be a problem on computers running SecureIT. Anyway, I was able to get in and renamed the conflicting file and they both booted up. Problem is, one of them booted into the XP Pro restarting setup screen, prompting for the disk. To me it looks like someone tried to repair this computer and somehow started a new windows install. They swear they didn't do anything.
Anyway, I've tried my XP Pro SP3 CD it is prompting for. It errors out. So I got their set of cd's they made from the recovery partition. It crapped out too. If there is a way, I would rather back out of the install to get it back to where it was. Is there a way to do that? To tell the system not to boot back into the setup? I looked at the boot.ini and it only shows one Windows and looks right. But... when I boot to the recovery console it does show me two windows installs. Any ideas? |
Dixit Mr Murphy : No matter how many resources you have, it is never enough |
That worked, but now it's booting to a blank desktop and saying I need to activate Windows. I tell it to but all I get is the desktop and a cursor.. no icons, no taskbar, nothing. No right-click, no Windows button, no CTRL-ALT-DELETE. Nothing. And I can't boot into safe mode cause it says I need to activate and can only do so in regular mode...
I checked the userinit in the registry to make sure it read right, and it does. Hm |
You are faced with a not so frequent problem here. You will have to use the WGA reset either by deleting the WGA files or be resetting the ootimer in the registry. This will give you access to either the three day activation or the general 30 day activation from your desktop.
I would suggest another method. Image the disk for safety, the delete the system32\drivers section and repair install. You may have to play arond a bit, but you will be able to get the system back up running again.
It seems repair install is the only option available to you. Try it this might solve your problem.
Free Technical assistance for your computer at Geeks-In-Route Land O'Lakes Florida. Call now at 866-661-4335 for computer repair |
| Thread Tools | |
| Display Modes | |
