ok this is what happened.
I download one of the Win 7 iso direct from msdn and then burn it with no problem at all. But once I followed one of the guide which to delete the ei.cfg file and then burn it into the same DVD and the error appear during the windows setup. Windows could not collect information for [OSImage] since the specified image file [install.wim] does not exist. Please help... |
The disk images are always fine, so I'd try burning at a slower speed (4x) and see if that fixes the issue
put that in your pipe and grep it |
nope.. it doesnt work.. this is stupid man.. wasted 10 DVDs -.-''
Try removing ei.cfg file manually. Copy contents of originally burned dvd to a directory. Locate ei.cfg file in sources folder and delete. Use imgburn to make into iso again and reburn the image. Make sure you make the image bootable though. Go to bootable disk and click on make image bootable. Set none for emulation type. For boot image, select \boot\etfsboot.com. Enter Microsoft Corporation in the Developer ID field. 07c0 in load segment field. 8 in sectors to load.
Use this as help: http://forum.imgburn.com/index.php?showtopic=11194 |
| Thread Tools | |
| Display Modes | |
