A few days ago I removed minor malware from a HP dv1000 with XP. This laptop went on my open network without issue.
I took it back today, and it would not connect to her Netgear router. 1. I ran Winsockfix 2. Reset all the IE-7 settings back to default 3. Made sure it is set for automatic DHCP 4. Flushed the DNS 5. Ipconfig /release and renew 6. Reset the router to factory default 7. Rebooted everything in the proper order I booted my laptop and went on instantly, and a new Win-7 Gateway got a quick connection too. I hard wired the HP and got a connection. On my way home, I stopped off at my nieces, and connected in her driveway. I tried pinging www.yahoo.com, and after a long spell, it did return 4 results – but still was not internet connected. So can anyone come up with a reason that it won’t connect to the Netgear? It works fine everywhere else. Any ideas as what to try next? Should I take over one of my old reliable WRT54gs? I just updated the intel wireless driver – just in case that might do something. Thanks for any help Packrat |
Check the hosts file for any redirects.
try in safe mode with networking try a different wireless utility - switch from manufacturer to MS or vice versa If you have an intel card and are using the intel software, connect to her router successfully, export the profile setup, import into her intel software. |
Hi, Winsockfix automatically resets the host file. I just looked and it is the correct 734 kb size. Nothing is in it.
I'm using the MS's utility. There is just "something" about that router and this laptop. Maybe I'll put in another HD (with a default install of XP), and look at what happens. Thanks for the reply. Packrat |
I took over a good old Linksys [WRT54G], and that solved the connection issue.
I always keep a stack of 5 or 6 of them. The version 5 and 6s are quite cheap on ebay. I update the firmware and put them on my network for a week of torrenting (multiple computers), Limewireing, and general home networking. They work just fine. And yes, I know about the early versions, and have few of those too. My favorite is the version 1 - for no particular reason. That's about all I know. Packrat1947 Last edited by Packrat1947; 03-03-2010 at 03:50 AM. Reason: clarification |
Thanks for the tips...
| Thread Tools | |
| Display Modes | |
