Old 09-30-2007, 06:56 PM
karthickips's Avatar
karthickips karthickips is offline
karthickips is an unknown quantity at this point
Default Ping command.
What is meant by ping command?What it does?
Old 10-01-2007, 05:34 AM
Bryce W's Avatar
Bryce W Bryce W is offline
Administrator
Bryce W will become famous soon enough
The Ping command is a network diagnostic tool. It can determine if a computer/network device is working and the speed it took for the signal to get there.
For example, if you were trying to connect to a website but it appeared to be not working. You could ping the websites server to see if the server is online. If it doesn't respond to ping its quite possible that the server is down.
If it does respond to ping it'll show you how long it took for your signal to get to the server and back. This is a good way to check to see if your internet connection is slow.
Here I did the ping command to the Technibble server. Since I got a reply it means that the Technibble server is running fine. The part that says "time=229ms" tells me how long it took for the signal to get back to me. 229ms for my connection to go from Australia to America is OK, but not great.
PHP Code:
Pinging www.technibble.com [72.9.151.30with 32 bytes of data:
Reply from 72.9.151.30bytes=32 time=229ms TTL=52
bytes=32 time=228ms TTL=52
bytes=32 time=227ms TTL=52
Ping statistics
for 72.9.151.30:
PacketsSent 4Received 4Lost (0loss),
Approximate round trip times in milli-seconds:
Minimum 227msMaximum 229msAverage 228ms
To access the ping command. Goto Start > Run and type CMD and press enter.
Then type: ping www.google.com
(replace www.google.com with any other site/ip address you want to ping)
Owner and Founder of Technibble - If you have a problem with any user, they are flaming/being elitist/making snide comments etc.. Press the report button which is on the top right of every post. This will highlight the post in an admin area for staff to see and deal with.
For adminly tasks such as username changes, moving threads etc.. please contact Martyn
Check out Technibbles twitter: http://www.twitter.com/technibble
