Old 09-28-2007, 05:25 AM
idiot_savant idiot_savant is offline
idiot_savant is on a distinguished road
Default Problem Detecting IDE Drives......
my sister-in-law's PC always hang up during boot up it hangs up on "Detecting IDE Drives......" All I do is to re-seat the IDE cables from the mobo and HDD...then the PC starts up.....It often happen and I always do the same thing pull up the cable and then put it back in......I tried to replace the IDE cable with a new one but its still the same.....what could be the problem here? is it the HDD having loose connection or is it the mobo that has a loose slot?
Old 09-29-2007, 12:09 AM
AnotherTechGuy AnotherTechGuy is offline
AnotherTechGuy is on a distinguished road
Send a message via ICQ to AnotherTechGuy
Default Try this
See if there is a Updated BIOS Flash for the systemboard
If you still have the same problem try different HDD
Old 09-29-2007, 12:57 AM
Noodle2732 Noodle2732 is offline
Noodle2732 is an unknown quantity at this point
Send a message via MSN to Noodle2732
I would..
1) Clean the slots, give them a blow to get any dust out or better yet use a can of compressed air.
2) Make sure the jumpers on the drive are correct (I cant personally see how it could cause this intermittent fault but i would still check
3) Try a different IDE HDD that you know works,
4) idealy if it still isnt working you would then want to try a diferrent motherboard.
If a new HDD did work then before you throw the other one away, try running a HDD check utility such as windows disk check (Warning: have had this delete data before. make a backup first!).
